Hi I just setup my new SmartMatrix with a 16x32 RGB panel. It looks fantastic and I’m surprised it wasn’t too difficult to put together.
I’m just having some problems with the scrolling text menus. The text is at the very bottom and basically cut off. This is after changing the following settings:
Got it, the sm3.0 branch has been merged into the main branch for Aurora, and then deleted. You can get the code just by downloading the .zip from Github, from the main page, not the releases page. The code to support 16x32 hasn’t been packaged up into a release yet.
Hey, sorry for the trouble. The last time I tried this on a 32x16 matrix the menus and most patterns worked fine, but it’s been a while. I’ll try it again as soon as I can and report back.
The vertical position for the menu scrolling text can be adjusted in the Aurora settings menu, have you tried that? You can also look on the SD card in the /aurora/menuY.txt file, which is where the setting is stored.
Great! It’s odd that you had to create the file to fix it, as it should default to centered vertically, based on the matrix height. Glad it’s working now, though.
I’ll try to get the other text centered vertically soon.
