Hello
I am getting a compile error when I use SmartMatrix and ArduinoJSON together, I am using PlatfromIO/VS Code as the IDE. According to a google search, the error I get seems to be related to when two things have been allocated the same memory by the compiler? or something. I don’t know enough details of C++, the error I get is:
In file included from .pio\libdeps\teensy41\ArduinoJson\src/ArduinoJson/Numbers/FloatTraits.hpp:14:0,
from .pio\libdeps\teensy41\ArduinoJson\src/ArduinoJson/Numbers/convertNumber.hpp:18,
from .pio\libdeps\teensy41\ArduinoJson\src/ArduinoJson/Variant/VariantData.hpp:9,
from .pio\libdeps\teensy41\ArduinoJson\src/ArduinoJson/Variant/SlotFunctions.hpp:8,
from .pio\libdeps\teensy41\ArduinoJson\src/ArduinoJson/Array/ArrayIterator.hpp:7,
from .pio\libdeps\teensy41\ArduinoJson\src/ArduinoJson/Array/ArrayRef.hpp:8,
from .pio\libdeps\teensy41\ArduinoJson\src/ArduinoJson.hpp:17,
from .pio\libdeps\teensy41\ArduinoJson\src/ArduinoJson.h:9,
from src\main.cpp:4:
.pio\libdeps\teensy41\ArduinoJson\src/ArduinoJson/Deserialization/DeserializationError.hpp:100:5: error: messages causes a section type conflict with lightPowerMap16bit
ARDUINOJSON_DEFINE_STATIC_ARRAY(
In file included from .pio\libdeps\teensy41\SmartMatrix\src/SmartMatrix.h:50:0,
from src\main.cpp:12:
.pio\libdeps\teensy41\SmartMatrix\src/MatrixCommon.h:387:31: note: 'lightPowerMap16bit' was declared here
static const PROGMEM uint16_t lightPowerMap16bit[] = {
*** [.pio\build\teensy41\src\main.cpp.o] Error 1
Here is the code I used to recreate this error, sorry its a bit long:
#include <Arduino.h>
#include <Wire.h>
#include <ArduinoJson.h>
// SmartMatrix Setup
#define INCLUDE_FASTLED_BACKGROUND
#include <FastLED.h>
const uint16_t kMatrixWidth = 64; // Set to the width of your display, must be a multiple of 8
const uint16_t kMatrixHeight = 64; // Set to the height of your display
const uint8_t kRefreshDepth = 36;
const uint8_t kDmaBufferRows = 6;
const uint32_t kMatrixOptions = (SM_HUB75_OPTIONS_NONE);
SMARTMATRIX_ALLOCATE_GFX_MONO_LAYER(messageLayer, kMatrixWidth, kMatrixHeight, kMatrixWidth*3, kMatrixHeight, COLOR_DEPTH, kScrollingLayerOptions);
const int defaultBrightness = (70*255)/100; // dim: 15% brightness
char jsonData[] = "{'coord':{'lon':-1.4659,'lat':53.383}, "
"'weather':[{'id':802,'main':'Clouds',"
"'description':'scattered clouds','icon':'03n'}],'base':'stations',"
"'main':{'temp':276.8,'feels_like':274.42,'temp_min':274.82,'temp_max':278.71,"
"'pressure':1009,'humidity':86},'visibility':10000,"
"'wind':{'speed':2.54,'deg':275,'gust':6.2},"
"'clouds':{'all':36},'dt':1620248072,"
"'sys':{'type':3,'id':2007943,'country':'GB','sunrise':1620188603,'sunset':1620243698},"
"'timezone':3600,'id':2638077,'name':'Sheffield','cod':200}";
void setupDisplayLayers() {
matrix.addLayer(&messageLayer);
messageLayer.setFont(font3x5);
messageLayer.setOffsetFromTop(2);
messageLayer.setColor(rgb24(0x07FF)); // cyan
messageLayer.setMode((ScrollMode)3);
Serial.begin(115200);
while (!Serial) {
Serial.println("ready");
setupDisplayLayers();
messageLayer.fillScreen(0);
messageLayer.drawString(3,6, 1, "Hello");
messageLayer.drawString(3,12, 1, "World");
messageLayer.swapBuffers();
StaticJsonDocument<1024> doc;
DeserializationError error = deserializeJson(doc, jsonData);
// Test if parsing succeeds.
if (error) {
Serial.print(F("deserializeJson() failed: "));
Serial.println(error.f_str());
return;
char* weatherDescription = doc["weather"]["description"];
Serial.println(weatherDescription);
// put your main code here, to run repeatedly:
Any Ideas how this can be fixed?
Karl
