heres the error code in full…
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: “Arduino Uno”
In file included from C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino:79:0:
C:\Users\nickm\Documents\Arduino\libraries\SmartMatrix\src/MatrixHardware_Teensy4_ShieldV5.h:41:17: note: #pragma message: MatrixHardware: SmartLED Shield for Teensy 4 (V5)
#pragma message "MatrixHardware: SmartLED Shield for Teensy 4 (V5)"
In file included from C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino:84:0:
C:\Users\nickm\Documents\Arduino\libraries\SmartMatrix\src/SmartMatrix.h:40:21: note: #pragma message: SmartMatrix Library version 4.000.003
# pragma message "SmartMatrix Library version 4.000.003"
In file included from C:\Users\nickm\Documents\Arduino\libraries\GifDecoder-master\src/GifDecoder.h:111:0,
from C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino:87:
C:\Users\nickm\Documents\Arduino\libraries\GifDecoder-master\src/GifDecoder_Impl.h: In member function 'int GifDecoder<maxGifWidth, maxGifHeight, lzwMaxBits, useMalloc>::startDecoding()':
C:\Users\nickm\Documents\Arduino\libraries\GifDecoder-master\src/GifDecoder_Impl.h:291:12: error: 'class HardwareSerial' has no member named 'printf'; did you mean 'print'?
Serial.printf("Successfully opened GIF; Canvas size = %d x %d\n", gif->getCanvasWidth(), gif->getCanvasHeight());
print
C:\Users\nickm\Documents\Arduino\libraries\GifDecoder-master\src/GifDecoder_Impl.h: In member function 'int GifDecoder<maxGifWidth, maxGifHeight, lzwMaxBits, useMalloc>::startDecoding(uint8_t*, int)':
C:\Users\nickm\Documents\Arduino\libraries\GifDecoder-master\src/GifDecoder_Impl.h:343:12: error: 'class HardwareSerial' has no member named 'printf'; did you mean 'print'?
print
C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino: At global scope:
AnimatedGifs:114:29: error: expected constructor, destructor, or type conversion before '(' token
AnimatedGifs:115:38: error: expected constructor, destructor, or type conversion before '(' token
AnimatedGifs:117:37: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino: In function 'void screenClearCallback()':
AnimatedGifs:147:3: error: 'backgroundLayer' was not declared in this scope
C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino:147:3: note: suggested alternative: 'kBackgroundLayerOptions'
C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino: In function 'void updateScreenCallback()':
AnimatedGifs:153:3: error: 'backgroundLayer' was not declared in this scope
C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino:153:3: note: suggested alternative: 'kBackgroundLayerOptions'
C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino: In function 'void drawPixelCallback(int16_t, int16_t, uint8_t, uint8_t, uint8_t)':
AnimatedGifs:159:5: error: 'backgroundLayer' was not declared in this scope
backgroundLayer.drawPixel(x, y, {red, green, blue});
C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino:159:5: note: suggested alternative: 'kBackgroundLayerOptions'
C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino: In function 'void setup()':
AnimatedGifs:186:5: error: 'matrix' was not declared in this scope
C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino:186:5: note: suggested alternative: 'atoi'
atoi
AnimatedGifs:186:22: error: 'backgroundLayer' was not declared in this scope
C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino:186:22: note: suggested alternative: 'kBackgroundLayerOptions'
AnimatedGifs:188:22: error: 'scrollingLayer' was not declared in this scope
AnimatedGifs:131:19: error: 'BUILTIN_SDCARD' was not declared in this scope
#define SD_CS BUILTIN_SDCARD
C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino:217:23: note: in expansion of macro 'SD_CS'
if(initFileSystem(SD_CS) < 0) {
C:\Users\nickm\AppData\Local\Temp\arduino_modified_sketch_857873\AnimatedGifs.ino:131:19: note: suggested alternative: '__BUILTIN_AVR_WDR'
exit status 1
"Show verbose output during compilation"
option enabled in File -> Preferences.
