Hi.
I used esp32 + smartmatrix + P10(3535)-4s-M2.1
esp32 + smartmatrix + P10 3in1-2M-4s-v1.12
but No work…
I want "PanelMappingEntry panelMap32x16Mod2[] = ???
help me Please.
Hi.
but No work…
help me Please.
Hi
but No work…
What doesn’t work?
Did you follow the instructions in the MultiRowRefreshMapping sketch?
If you post your code and a video of what you see on the panel that can be useful for troubleshooting
Hi Louis. .
this led P10 3in1-2m-4s-v1.12 use map …
const PanelMappingEntry panelMap32x16Mod2[] =
{0, 7, -8},
{0, 23, -8},
{0, 39, -8},
{0, 55, -8},
{2, 71, -8},
{2, 87, -8},
{2, 103, -8},
{2, 119, -8},
{4, 8, 8},
{4, 24, 8},
{4, 40, 8},
{4, 56, 8},
{6, 72, 8},
{6, 88, 8},
{6, 104, 8},
{6, 120, 8},
{0, 0, 0} // last entry is all zeros//–
“TEST P10”
“4S” means you have a MOD4 panel, so you should be trying the existing MOD4 panel maps, or using the MultiRowMapping sketch to reverse engineer your layout and make your own panel map
hi Louis
Is there anything recommended for scanning? And observation
