I have four panels in a 64x64 configuration. The same color on different panels (e.g., white) noticeably differs. Does SmartMatrix have support for tuning each panel to get the colors to match?
I’d be happy to work on a pull request, if someone can point me to the relevant code sections.
There’s no support for this. Here’s the code (assuming you’re refreshing with 36-bit color) that pulls pixel data from layers and puts it in a row buffer before shifting it out to the panels. You could put some color balancing code in here.
Problem may be some panels are RGB and some are RBG, so blue and green are exchanged. If its the problem then you will must to change connections in panel that is different.
I have here some P2.5 led panels, some RGB, some RBG, then when play same, colors are different in each panel, green exchange by blue, yellow by pink, etc…
At any rate, white color must to be always same in all led panels because mix the three basic colors RGB.
Sounds like a mistake in hardware to me. The HUB75 pinout sets pin positions for R G and B and the manufacturer didn’t follow it. I would fix it in hardware as well, making custom cables to swap the colors to and from the panels that need it. You could minimize the number of custom cables needed by grouping similar panels
Some manufacturers, currently do RBG panels instead of RGB. I know HUB75 pinout define clearly each pin position, and this may be some problem for designs based on HUB75.
Currently I order in quantity, P2.5 LEd panels from a manufacturer, and recently he changed design to improve it, but also he changed the data pinout, and now the new design is RBG instead of RGB. I realized about it, when connected to my custom board and all colors were different. Also the manufacturer changed the position of data and power supply connectors, so I had to modify two times my PCB design.
