Is driving 32 x 256 possible? ( 4 screens with 32 x 64 )
I did have a good half hour searching around for this answer. I’d like to use a teensy 3.5 but i’ll have to use whichever board that will get the job done, so please recommend the best board for this high number of LEDs.
I think @marcmerlin had luck with a Teensy 3.6 and 128x64 pixels. Maybe 256x32 will work. You can try it, even if you just have one panel, set the size to 32x256 and see if it visibly works for one panel. It will be sending the data for all the pixels.
