Led module P2 128*64 1/32 driver
Hello,
I’m new in this forum and a newbie with led module.
I would like to do my own driver (with a PIC) for a PH2-128*64-32s-V1.0 led module.
the ship use for the P2 module is ICN2038S.
On the flat connector HUB75 only have only 3 address labeled A,B,C no pin D and E.
I have check the connectivity with the ground to be sure it was not an error on the silk screen of the board.
I have already do my driver for an P4 module 32*64 1/16scan with ABCD address line and it is working good. (but the ship use is a MBI5124).
but I don’t understand why for 1/32 scan they are only 3 adress bit ???
ca you help me to understand how it works?
Take a look at these threads:
thanks for your help.
I have add the 3 clock inside the latch pulse, but there is not a big difference.
I have now half of all display light on. 1 ligne on and the next off, I don’t use the ABC ligne correcly i think.
I don’t understand the use of these 3 ligne ABC because that give 8 cs posibilities and not 32 like the 1/32 scan write on the silk screen of the led module.
I have take off the plastic protection of the module to look where is connected the ABC ligne,
ABC ligne are connected to 8 RT5957SP, ligne A and B are common for all of the 8 RT5957SP and the C ligne si juste conected to the firts, the 8 RT5957 are chained (like a shift register) but I don’t yet find the datasheet of the RT5957SP, this is 16 pin componant
  • Ligne A is connected (via a buffer 74HC245) to the pin 3 of the 8 RT5957SP
  • Ligne B is connected (via a buffer 74HC245) to the pin 4 of the 8 RT5957SP
  • Ligne C is connected (via a buffer 74HC245) to the pin 2 of the 1st RT5957SP
    the 1st RT5957SP has pin 10 connected to the pin 2 of the second RT5957SP …
Pin 1 and 11 connected to VCC
Pin 9 connected to GND.
I have found the datashett of this componant on Raffar Technology
http://www.raffar.com.tw/product-display-page.php?mod=RT5957
http://www.88869188.com/uploads/201805/5b03e7bc77f3a.pdf
the datasheet is in chinis but with google traduction that is understanding
But There is no explication about the timing, I have send a email of the productor and I hope to receive a response.
I haven’t researched the AB-addressing scheme, and don’t know what the C signal would be used for, but my understanding was that either A or B is used as a CLK signal going to the addressing chip, and the other one (B or A) is used as a DAT signal, so you shift in the address while the LAT signal is held high. Hopefully you can find out how these chips actually are used and get your panel working
@vinowan PxMatrix may support those panels according to
PxMatrix/PxMatrix.h at master · 2dom/PxMatrix · GitHub
and PxMatrix/PxMatrix.h at master · 2dom/PxMatrix · GitHub
would you like to give it a shot and report back?
I have received the datasheet of the RT5957 used for the addressing with pin A,B,C of the P2 led module and an note for the timing require.
the module use 8 chip RT5957 (shift register) for the 64 row of addressing (the P2 module is 128*64 led)
it need to use 1 data to 1 each 32 clock for adresing in the same time the 1st row of the upper and the 1rst row of the lower part of the dipslay. (I’m not sure that the 8 chip RT5957 use all of the 64 output or only 4 output of all RT5957 and each output is connected to the upper and the lower part of the module but that nothing change for then programmation).
pin A = Clock
pin B = BK (blank like a latch)
pin C = Data in
I don’t know if I can post the datasheet in the forum?
here is the contact in “Raffar Technology Corp”
Oliga Lin oligalin@raffar.com.tw
If PDF attachments aren’t working for you, email it to me and I’ll host it: hello@pixelmatix.com
Hi
I try to control a 32x32RGB panel directly (HUB73, MBI5151 + RT5958). The RT5958 is controlled via A,B,C. Since the timing of the RT5958 is only partly clear to me (what exactly does BK do?) I am looking for a data sheet with timing. I assume that the control of the RT5957 is the same.
I just took a look at the first google result, incomplete data sheet in Chinese, and DK looks like an OE signal to me, but I could be wrong
PH2-128*64-32s-V1.0 work PxMatrix and esp32.
Great ! May you please post your working configuration ? I have a similar panel and I’m trying to make it work with ESP32 Trinity.
// This is how many color levels the display shows - the more the slower the update
//#define PxMATRIX_COLOR_DEPTH 4
// Defines the speed of the SPI bus (reducing this may help if you experience noisy images)
//#define PxMATRIX_SPI_FREQUENCY 20000000
// Creates a second buffer for backround drawing (doubles the required RAM)
#define PxMATRIX_double_buffer true
#include <PxMatrix.h>
#include “anim_data.h”
// Pins for LED MATRIX
#ifdef ESP32
#define P_LAT 22
#define P_A 19
#define P_B 23
#define P_C 18
#define P_D 5
#define P_E 15
#define P_OE 16
hw_timer_t * timer = NULL;
portMUX_TYPE timerMux = portMUX_INITIALIZER_UNLOCKED;
#endif
#ifdef ESP8266
#include <Ticker.h>
Ticker display_ticker;
#define P_LAT 16
#define P_A 5
#define P_B 4
#define P_C 15
#define P_D 12
#define P_E 0
#define P_OE 2
#endif
#define matrix_width 128
#define matrix_height 64
#define RGB 565
#if RGB==565
#define frame_size matrix_widthmatrix_height2
#else
#define frame_size matrix_widthmatrix_height3
#endif
uint16_t frame_no=0;
unsigned long anim_offset=0;
union single_double{
uint8_t two[2];
uint16_t one;
} this_single_double;
// This defines the ‘on’ time of the display is us. The larger this number,
// the brighter the display. If too large the ESP will crash
uint8_t display_draw_time=10; //30-70 is usually fine
PxMATRIX display(128,64,P_LAT, P_OE,P_A,P_B,P_C);
//PxMATRIX display(64,32,P_LAT, P_OE,P_A,P_B,P_C,P_D);
//PxMATRIX display(64,64,P_LAT, P_OE,P_A,P_B,P_C,P_D,P_E);
// Some standard colors
uint16_t myRED = display.color565(255, 0, 0);
uint16_t myGREEN = display.color565(0, 255, 0);
uint16_t myBLUE = display.color565(0, 0, 255);
uint16_t myWHITE = display.color565(255, 255, 255);
uint16_t myYELLOW = display.color565(255, 255, 0);
uint16_t myCYAN = display.color565(0, 255, 255);
uint16_t myMAGENTA = display.color565(255, 0, 255);
uint16_t myBLACK = display.color565(0, 0, 0);
uint16_t myCOLORS[8]={myRED,myGREEN,myBLUE,myWHITE,myYELLOW,myCYAN,myMAGENTA,myBLACK};
#ifdef ESP8266
// ISR for display refresh
void display_updater()
display.display(display_draw_time);
#endif
#ifdef ESP32
void IRAM_ATTR display_updater(){
// Increment the counter and set the time of ISR
portENTER_CRITICAL_ISR(&timerMux);
portEXIT_CRITICAL_ISR(&timerMux);
#endif
void display_update_enable(bool is_enable)
#ifdef ESP8266
if (is_enable)
display_ticker.attach(0.001, display_updater);
else
display_ticker.detach();
#endif
#ifdef ESP32
if (is_enable)
timer = timerBegin(0, 80, true);
timerAttachInterrupt(timer, &display_updater, true);
timerAlarmWrite(timer, 2000, true);
timerAlarmEnable(timer);
else
timerDetachInterrupt(timer);
timerAlarmDisable(timer);
#endif
unsigned long getAnimOffset(uint8_t anim_no)
unsigned long offset=0;
for (uint8_t count=0;count<anim_no;count++)
  offset=offset+animation_lengths[count]*frame_size;
//Serial.println("anim_no: " + String(anim_no) + ", length: " + String(animation_lengths[anim_no])+ ", offset: " + String(offset));
return offset;
uint8_t line_buffer[matrix_width*2];
// This draws the pixel animation to the frame buffer in animation view
void draw_image ()
unsigned long frame_offset=anim_offset+frame_no*frame_size;
for (int yy=0;yy<matrix_height;yy++){
memcpy_P(line_buffer, animations+frame_offset+yymatrix_width2, matrix_width*2);
for (int xx=0;xx<matrix_width;xx++){
  this_single_double.two[0]=line_buffer[xx*2];
  this_single_double.two[1]=line_buffer[xx*2+1];
  display.drawPixelRGB565(xx,yy, this_single_double.one);
yield();
void setup() {
Serial.begin(9600);
// Define your display layout here, e.g. 1/8 step, and optional SPI pins begin(row_pattern, CLK, MOSI, MISO, SS)
display.begin(32);
//display.begin(8, 14, 13, 12, 4);
// Define multiplex implemention here {BINARY, STRAIGHT} (default is BINARY)
//display.setMuxPattern(BINARY);
// Set the multiplex pattern {LINE, ZIGZAG,ZZAGG, ZAGGIZ, WZAGZIG, VZAG, ZAGZIG} (default is LINE)
//display.setScanPattern(LINE);
// Rotate display
//display.setRotate(true);
// Flip display
//display.setFlip(true);
// Control the minimum color values that result in an active pixel
//display.setColorOffset(5, 5, 5);
// Set the multiplex implemention {BINARY, STRAIGHT} (default is BINARY)
display.setMuxPattern(SHIFTREG_ABC);
// Set the color order {RRGGBB, RRBBGG, GGRRBB, GGBBRR, BBRRGG, BBGGRR} (default is RRGGBB)
display.setColorOrder(BBGGRR);
// Set the time in microseconds that we pause after selecting each mux channel
// (May help if some rows are missing / the mux chip is too slow)
//display.setMuxDelay(0,1,0,0,0);
// Set the number of panels that make up the display area width (default is 1)
//display.setPanelsWidth(2);
// Set the brightness of the panels (default is 255)
//display.setBrightness(50);
// Set driver chip type
display.setDriverChip(FM6124);
display.clearDisplay();
display.setTextColor(myCYAN);
display.setCursor(2,0);
display.print(“Pixel”);
display.setTextColor(myMAGENTA);
display.setCursor(2,8);
display.print(“Time”);
display_update_enable(true);
display.showBuffer();
delay(1000);
Serial.println("Initi complete");
void loop() {
for (uint8_t anim_index=0; anim_index<sizeof(animation_lengths)-1;anim_index++)
// Display image or animation
anim_offset=getAnimOffset(anim_index);
frame_no=0;
unsigned long start_time=millis();
while ((millis()-start_time)<8000)
  draw_image();
  //Serial.println(anim_offset);
  frame_no++;
  if (frame_no>=animation_lengths[anim_index])
    frame_no=0;
  delay(100);
// Display static
anim_offset=getAnimOffset(5);
frame_no=0;
while ((millis()-start_time)<1000)
  draw_image();
  frame_no++;
  if (frame_no>=animation_lengths[5])
    frame_no=0;
  delay(50);
bat fille -
ffmpeg -i 1.gif -vf “scale=128:64, lutyuv=y=gammaval(1.4)” -vcodec rawvideo -f rawvideo -pix_fmt rgb24 1.rgb
