What started as a hunt for demo code turned into me working on getting the Aurora patterns to work on a 64x64 matrix. No audio, weather, IR, etc. just gorgeous eye candy. I basically started with the sm3 branch of Aurora and gutted the functionality that wasn’t relevant. Here’s what the file list looks like
Attractor.h
Boid.h
Drawable.h
Effects.h
Geometry.h
Menu.h
MenuItem.h
PatternAnalogClock.h
PatternAttract.h
PatternBounce.h
PatternCube.h
PatternElectricMandala.h
PatternFire.h
PatternFlock.h
PatternFlowField.h
PatternIncrementalDrift.h
PatternIncrementalDrift2.h
PatternInfinity.h
PatternInvaders.h
PatternLife.h
PatternMaze.h
PatternMunch.h
PatternNoiseSmearing.h
PatternPendulumWave.h
PatternPlasma.h
PatternPongClock.h
PatternPulse.h
PatternRadar.h
PatternRainbowSmoke.h
Patterns.h
PatternSimplexNoise.h
PatternSnake.h
PatternSpark.h
PatternSpin.h
PatternSpiral.h
PatternSpiro.h
PatternSwirl.h
PatternWave.h
Playlist.h
Runnable.h
Vector.h
Relevant includes from the main sketch
#include <SmartMatrix3.h>
#include <FastLED.h>
Not too surprisingly, I’m overflowing .bss by 17K (down from about 28K).
Here’s the gcc invocation
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1443091078
-TC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/mk20dx256.ld -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp/NorthernLights.cpp.elf
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\NorthernLights.cpp.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\SmartMatrix3\Font_apple4x6_256.c.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\SmartMatrix3\Font_apple5x7_256.c.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\SmartMatrix3\Font_apple6x10.c.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\SmartMatrix3\Font_apple8x13.c.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\SmartMatrix3\Font_gohufont6x11.c.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\SmartMatrix3\Font_gohufont6x11b.c.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\SmartMatrix3\Font_tom_thumb.c.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\SmartMatrix3\CircularBuffer.cpp.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\SmartMatrix3\Layer.cpp.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\SmartMatrix3\MatrixFont.cpp.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\SmartMatrix3\SmartMatrix.cpp.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\FastLED\colorpalettes.cpp.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\FastLED\colorutils.cpp.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\FastLED\FastLED.cpp.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\FastLED\hsv2rgb.cpp.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\FastLED\lib8tion.cpp.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\FastLED\noise.cpp.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\FastLED\power_mgt.cpp.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp\FastLED\wiring.cpp.o
C:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp/core.a
-LC:\Users\rhett\AppData\Local\Temp\build2745775725840725466.tmp -larm_cortexM4l_math -lm
I’m interested in seeing how much closer I can get if I can cut out all or most of the fonts since I’m not interested in using them. I’m new to this toolchain and it seems my naive attempts at changing the font code to only reference the apple3x5 (or similar) font isn’t doing the trick?
Oh I have also removed the scrolling and indexed layers and poked around at a few of the parameters to the ALLOCATE_XXXX macros.
Would appreciate any guidance you may have on trying to trim the fat.
PS: There are a few object files created that I don’t think I “need” like various USB items, AudioStream, etc.
