In order not to spam https://github.com/hzeller/rpi-rgb-led-matrix/issues/823 with non relevant content, I thought I’d make a new thread here.
There are 2 issues, on P2 panels, pixels are so small that they fall off easily, especially in the corners.
Amazon.com is supposed to be a waterproof coating, I’m not sure how well it works as a surface glue that doesn’t impact visibility yet, nor have I gotten the right applicator for it yet either.
Amazon.com is supposed to be better for that job, but not sure how much it will impact visibility and reflections.
Problem #2 for flexible panels (my main use) is that the chips in the back eventually get some feet cracked of desoldered or the trace on the board breaks (no idea which one, I’ve never seen the actual damage). Pushing on the back of the board makes the problem go away until the pressure is removed.
Usually I lose a half column of one color, once I lost a whole square, I think I’ve also lost lines depending on which connection is lost.
This is quite annoying as I have to replace the panels when this happens as I’m not suitably equipped to find the problem and fix them.
This also makes me weary of ever upgrading to 128x64 flexible panels that @Louis pointed me to (although they were P2.5 when I need P2) as they’ll likely be even more brittle.
I think I might settle for non flexible panels if they were as flat as possible (without the thick frame around them) and had enough self support not to bend/break without the frame.
Suggestions/ideas welcome
