Hello !
I’ve made a custom PanelMap for a 128x32 panel that’s actually composed out of two 64x32 panels.
MODE_MAP_TESTING
works perfectly.
I’ve made a simple scroll text method:
//------------------------- scroll_text()
void scroll_text(String text, uint16_t color, uint8_t ypos) {
uint16_t text_length = text.length();
matrix->clear();
matrix->setTextWrap(false);
matrix->setRotation(0);
matrix->setFont(&FreeSans9pt7b);
matrix->setTextColor(color);
for(int xpos = mw; xpos > - (mw + text_length*9); xpos--) {
matrix->clear();
matrix->setCursor(xpos,ypos);
matrix->print(text);
yield();
matrix->show();
delay(20);
The problem I am seeing is that the scroll text stutters. It’s not fluid.
I am currently not using a power source and I’m also not using Logic Level Converters. I’ve set the brightness pretty low.
I’ve tried both
const uint8_t kRefreshDepth = 24;
and
const uint8_t kRefreshDepth = 48;
but the result is the same.
Increasing const uint8_t kDmaBufferRows = 2;
to 3 or 4 amplifies the stutter effect.
Here is a video: LED_128x32 - YouTube
The panels are reversed because I don’t have a long ribbon to connect them.
What do you think the cause is ?
Thank you !
