Hello !
I am trying to run a simple code using this library, but I can’t, because I added WiFi to it and it crashes like crazy.
This is the code:
#include <Arduino.h>
#include <SmartMatrix3.h>
#include <WiFi.h>
const uint8_t kPanelType = SMARTMATRIX_HUB75_32ROW_64COL_MOD8SCAN_L540_2727; // use SMARTMATRIX_HUB75_16ROW_MOD8SCAN for common 16x32 panels
const int defaultBrightness = (100*255)/100; // full (100%) brightness
const int Brightness_15 = (15*255)/100; // dim: 15% brightness
const rgb24 defaultBackgroundColor = {0x40, 0, 0};
#define WHITE rgb24(0xFF,0xFF,0xFF)
#define BLACK rgb24(0x00,0x00,0x00)
#define CYAN rgb24(0x00,0xFF,0xFF)
#define RED rgb24(0xFF,0x00,0x00)
#define DEMO_INTRO 1
#define DEMO_BRIGHTNESS 1
void triangles() {
backgroundLayer.setBrightness(Brightness_15);
backgroundLayer.drawTriangle(41,5,41,25,58,15,WHITE);
backgroundLayer.fillTriangle(41,5,41,25,58,15,WHITE);
// backgroundLayer.swapBuffers();
char* IPAddr;
const char* ssid = "ssid";
const char* password = "password";
Serial.begin(115200);
delay(500);
WiFi.begin(ssid, password);
delay(500);
int k = 0;
while (WiFi.status() != WL_CONNECTED && k<20) {
k++;
delay(1000);
Serial.println((String)"Attempt " + k + " - Connecting to WiFi..");
delay(1000);
scrollingLayer.setOffsetFromTop(defaultScrollOffset);
if(WiFi.status() == WL_CONNECTED) {
String IP = WiFi.localIP().toString();
IP.toCharArray(IPAddr,IP.length());
Serial.println((String)"Connected to " + ssid + " with IP addres: " + IPAddr);
scrollingLayer.setColor(CYAN);
scrollingLayer.setFont(font5x7);
// scrollingLayer.setCursor(1,1);
scrollingLayer.start(IPAddr,1);
delay(50);
} else {
Serial.println("Couldn't connect to WiFi Network. Restarting in 5 seconds...");
scrollingLayer.setColor(RED);
scrollingLayer.start("Error 1 - Restarting in 5 sec!",1);
delay(5000);
ESP.restart();
triangles();
// // unsigned long currentMillis;
// backgroundLayer.fillScreen(BLACK);
// #if (DEMO_INTRO == 1)
// // "SmartMatrix Demo"
// // backgroundLayer.fillScreen(BLACK);
// scrollingLayer.setColor(WHITE);
// scrollingLayer.setMode(wrapForward);
// scrollingLayer.setSpeed(40);
// scrollingLayer.setFont(font6x10);
// scrollingLayer.start("SmartMatrix Demo", 1);
// delay(5000);
// #endif
// triangles();
This is what I get on the Serial Monitor:
Attempt 1 - Connecting to WiFi..
Starting SmartMatrix Mallocs
Heap/32-bit Memory Available: 279744 bytes total, 113792 bytes largest free block
8-bit/DMA Memory Available : 226188 bytes total, 113792 bytes largest free block
SmartMatrix Layers Allocated from Heap:
Heap/32-bit Memory Available: 265940 bytes total, 113792 bytes largest free block
Starting SmartMatrix DMA Mallocs
sizeof framestruct: 00004000
DMA Memory Available before ptr1 alloc: 179168 bytes total, 113792 bytes largest free block
matrixUpdateFrames[0] pointer: 3FFCBC0C
DMA Memory Available before ptr2 alloc: 177460 bytes total, 113792 bytes largest free block
matrixUpdateFrames[1] pointer: 3FFCFC1C
Frame Structs Allocated from Heap:
Heap/32-bit Memory Available: 232724 bytes total, 113792 bytes largest free block
8-bit/DMA Memory Available : 179168 bytes total, 113792 bytes largest free block
Allocating refresh buffer:
lsbMsbTransitionBit of 0 requires 24576 RAM, 113792 available, leaving 89216 free:
Raised lsbMsbTransitionBit to 0/7 to fit in RAM
lsbMsbTransitionBit of 0 gives 76 Hz refresh, 120 requested:
lsbMsbTransitionBit of 1 gives 152 Hz refresh, 120 requested:
Raised lsbMsbTransitionBit to 1/7 to meet minimum refresh rate
Descriptors for lsbMsbTransitionBit 1/7 with 8 rows require 12288 bytes of DMA RAM
SmartMatrix Mallocs Complete
Heap/32-bit Memory Available: 220404 bytes total, 113792 bytes largest free block
8-bit/DMA Memory Available : 166848 bytes total, 113792 bytes largest free block
Setting up parallel I2S bus at I2S1
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400014fd PS : 0x00060430 A0 : 0x800d1dfc A1 : 0x3ffb1f10
A2 : 0x00000000 A3 : 0xfffffffc A4 : 0x000000ff A5 : 0x0000ff00
A6 : 0x00ff0000 A7 : 0xff000000 A8 : 0x00000000 A9 : 0x3ffb1ee0
A10 : 0x3ffb80c0 A11 : 0x3ffbbf54 A12 : 0x00000000 A13 : 0x0000ff00
A14 : 0x00ff0000 A15 : 0xff000000 SAR : 0x00000004 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xffffffff
ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000
Backtrace: 0x400014fd:0x3ffb1f10 0x400d1df9:0x3ffb1f20 0x400d28fd:0x3ffb1f40 0x400d5683:0x3ffb1fb0 0x4008ef39:0x3ffb1fd0
Rebooting...
Decoding stack results
0x400d1dfd: Print::printNumber(unsigned long, unsigned char) at /home/george/Arduino/hardware/espressif/esp32/cores/esp32/Print.cpp line 246
0x400d292d: loopTask(void*) at /home/george/Arduino/hardware/espressif/esp32/cores/esp32/main.cpp line 20
0x400d56bf: _fseeko_r at ../../../.././newlib/libc/stdio/fseeko.c line 146
