There is no need for the 16 pin block to start at pin D00 or D16. FlexIO allows you to pick any pin as the start of the 16 pin block, so you can choose D01-D16 or D11-D26.
The selection you indicated should also work.
Ok, thanks, now I understand, everything is already clarified.
Aha! These changes fixed the pixel flicker issues I was having when using SPI. I can run things at 600MHz now
Hi folks,
Apologies if I’m missing something obvious here, but I’m stumped.
I got Louis’ OshPark adapter and a 4.1 a few days ago, and I pulled down the “teensy4” branch from the repo. I can’t seem to get it to compile at all. Here’s what I’m seeing:
In file included from [fullpath]\Arduino\libraries\SmartMatrix-teensy4\src/SmartLEDShieldV4.h:5:0,
from [fullpath]\Local\Temp\arduino_modified_sketch_373068\FeatureDemo.ino:6:
[fullpath]\Arduino\libraries\SmartMatrix-teensy4\src/SmartMatrix3.h:44:19: error: No MatrixHardware*.h file included - You must include one at the top of your sketch
#pragma GCC error "No MatrixHardware*.h file included - You must include one at the top of your sketch"
I was able to roll back my library to “master” and switch over to a Teensy 3.2 on the same hardware which compiled with a few warnings. For reasons I can’t understand, the “teensy4” branch gives me that weird error. (That forward slash in the error message path looks ominous fwiw)
I’m on Arduino 1.8.12 / Teensyduino 1.52 if that helps. Please advise.
@Louis is changing how things work, see SmartMatrix Library 4.0 - Changes to MatrixHardware #includes - #4 by Louis
Right now, with the Teensy4 branch, you need to include one of the following headers before you include SmartMatrix:
MatrixHardware_KitV4T4.h (if you are using jumpers to rewire the shield)
MatrixHardware_T4Adapter.h (if you are using the OSHpark adapter)
SmartLEDShieldV4.h is not used anymore.
We are testing a new version of the shield designed specifically for T4.x, which will probably have a different named header.
I need to bring the examples in the teensy4
branch up to date to show how to include the MatrixHardware*.h
file. Most examples in the NT
branch show how to include the file. I’ll merge these over to the teensy4
branch at some point, hopefully soon:
Thanks, all. I got it working by using the proper include. I’m going to order a teensy 4.1 so I can use the onboard SD card. I’ll put it thru its paces soon.
I am also preparing my own board for testing, I already received the Teensy 4.1, and today the PCB of my own board with a different pin assignment to have the LPSPI4 port free.
I also ordered some 8MB PSRAM chips, to add two to Teensy 4.1, so I will have an extra 16MB of RAM. Any variable or array can be assigned to that PSRAM by adding the EXTMEM prefix to the variable definition. PJRC Store
I have yet to finish another design of my own board with the RT1062 microcontroller, instead of using a Teensy, but first I want to try the Teensy because it is easier. It will be my first board with BGA chips.
There’s hasn’t been any updates in a while but there’s a lot going on:
The Teensy 4 is really powerful, and able to push a lot of pixels to the panels. I’m going to need to update SmartMatrix Library to make sure some of the uint8_t
types used in older code (when any dimension of the display approaching 256 seemed far out of reach), are replaced with uint16_t
so displays wider/taller than 256 pixels can be driven. 128x128 pixel Animated GIFs can be decoded and driven to a 128x128 36-bit color 240Hz refresh display at 100% speed.
From what I’ve tested so far, 128x128 with high color depth and high refresh rate doesn’t seem to be pushing the limits of the Teensy 4. (edit: see next post)
What does push the limits? @marcmerlin I tried your use case of 128x192 pixels, wanting a high refresh rate and willing to sacrifice color depth. Best it can do so far is 24 bit color, 130 Hz refresh, decoding the 128x192 GIF I tested at 77% of full speed. Eric added some code to lower refresh rate below 24 for the Teensy 4, but for some reason I get lower refresh rate with that code. Not perfect, but at least promising!
Looks like I made a mistake while testing and 128x128 isn’t actually able to do 240Hz refresh.
Summary of max refresh seen when testing GIF (128x128) decoder sketch with matrix.setRefreshRate(240)
128x128/32 36-bit color: 157Hz isn’t a bad result, but I got used to seeing no tearing when taking pictures or video of panels running at 240Hz refresh, and now I can’t go back! I think the limit is mostly to do with the time it takes to shift out pixels to the panels, with some pauses between to make sure all pixels make it out before the latch signal toggles. At 20MHz HUB75 clock speed, just the time to clock out 256 pixels x 12 times for 36-bit color, across 32 rows gives a theoretical max refresh rate of only ~203 Hz, add in pauses before and after each latch, and the refresh rate is down to 157Hz. 1/(1/20000000*256)/12/32 = 203.45
I was curious about Louis’s comment about lower color depths, so I did some more tests with the latest library. Here’s some results running a plain bitmap test (no GIF decoding) with a background, scrolling, and indexed layer. These results are for Teensy 4.1 running at 600 MHz on the “Fastest” optimize setting. I’m using 32-row/mod16 panel size.
128x128 | 128x192 | 128x256 | |
48-bit | 121 Hz | 82 Hz | 62 Hz |
36-bit | 163 Hz | 109 Hz | 82 Hz |
24-bit | 244 Hz | 164 Hz | 123 Hz |
15-bit | 327 Hz* | 220 Hz* | 171 Hz* |
9-bit | 412 Hz* | 278 Hz* | 208 Hz* |
With the lower bit depths (starred), I found that if I tried to set a refresh rate higher than the max stable value, the buffers would under-run and the driver would adjust the refresh rate all the way to 50-65% of the max before stabilizing. This probably explains why Louis was seeing lower refresh rates.
It looks like the 24-48 bit settings are HUB75 clock speed limited since they all are pushing about 96 million bits per second. But the lower color depth settings appear to be CPU speed limited instead. (If I overclock the Teensy to 816 MHz, I can get higher refresh rates for < 24 bit.)
I did some further digging and I think that the processing bottleneck is the code that extracts pixel data from all the layers (which is the same speed regardless of display color depth). Interestingly, it appears the majority of the CPU time is used decoding the scrolling and indexed layers.
No doubt with CPU-intensive rendering, the maximum refresh rates are going to be lower.
After disabling the indexed and scrolling layers, and making a minor speedup to the background layer I am now getting clock speed limited refresh rates at 9 and 15 bit:
15-bit | 392 Hz | 263 Hz | 198 Hz |
9-bit | 654 Hz | 439 Hz | 331 Hz |
Eric, thanks for looking into this. Scrolling I’m aware is inefficient, I wasn’t aware of indexed. I’ll have to take a look at some point.
If anyone thinks improving the efficiency of these layers is important for the next major release, please let me know. It’s not a high priority for me personally.
Tl;dr there’s a lot of updates to HUB75 code, and any existing projects using stacked panels need to be updated as SMARTMATRIX_OPTIONS_BOTTOM_TO_TOP_STACKING
logic is now reversed.
The teensy4
branch has a lot of new updates:
I added the missing C-shaped stacking to all platforms, and added MultiRowRefresh to Teensy 4. In the process of adding these I realized that the SMARTMATRIX_OPTIONS_BOTTOM_TO_TOP_STACKING
option was reversed. By default stacking was bottom to top, and enabling SMARTMATRIX_OPTIONS_BOTTOM_TO_TOP_STACKING
would stack top to bottom. I fixed the logic, but anyone using stacking in the Teensy 4 branch will end up with reversed stacking logic when they update, so be careful there.
It turned out to be difficult to support MultiRowRefresh panels with C-shaped stacking, so they aren’t supported. MultiRowRefresh panels can only use Z-shaped stacking.
@easone’s loadMatrixBuffers() refactoring for the Teensy 4 is a lot easier to read, and is more efficient (~30% more) than my old code for Teensy 3, so I refactored the Teensy 3 loadMatrixBuffers() to get the improved efficiency, and also allowing kRefreshDepth to be any multiple of 3 instead of just 24, 36, 48.
I also added the hardware files for SmartLED Shield for Teensy 4 V5 (the production version that will be shipping to Crowd Supply backers).
I pushed some more updates today. A few things that will break existing sketches unfortunately, but hopefully the long term benefits are worth the temporary issues. Major changes that may break existing sketches, or cause some merge issues with forked code:
SmartMatrix-Platform-LEDType-ClassType
, e.g. SmartMatrixTeensy4Hub75Refresh
MatrixHardwareKit_V1.h
is now MatrixHardware_Teensy3_ShieldV1toV3.h
I wasn’t perfectly consistent with using HUB75
vs Hub75
, and I think I like the latter better e.g. SmartMatrixTeensy3HUB75Calc_Impl
vs SmartMatrixTeensy3Hub75Calc_Impl
so I’m going to do another renaming pass.
I still need to figure out what to do with the class and library name, as I foolishly named both “SmartMatrix3” instead of just “SmartMatrix”. I’m planning to rename them and request Arduino Library Manager to change the library name. I hope this doesn’t cause problems where people have an out of date “SmartMatrix3” library folder and a current “SmartMatrix” library folder, but I think changing the top of the sketch from #include <SmartMatrix3.h>
to #include <SmartMatrix.h>
and using the new MatrixHardware file name will sort things out, as these names will be unique to SmartMatrix Library 4.0, and the teensy4
development branch.
SmartLED Library 4.0 has been released on GitHub and Arduino Library Manager
Thanks for all your hard work here. I appreciate it.
Thanks Mark! It was a lot of work, but the payoff is when I get to see and hear about cool projects people are building with the library
