I tried the module with an Arduino UNO : everything worked fine.
But when I try to use it with the smartmatrix shield and my Teensy 3.2, it didn’t work.
Do you have an idea on how I can adapt the voicerecognitionV3 library for the smartmatrix shield ?
Does the module work with the Teensy 3.2 without the SmartMatrix Shield? Are you starting the SmartMatrix Library and driving the matrix display at the same time? What if you don’t use the SmartMatrix Library?
I didn’t start the SmartMatrix library.
I use pins 5v, Gnd, 11 (OUT) and 12 (IN) of the smartmatrix.
I can’t test the module with Teensy only (because it’s now solded on the smartmatrix shield).
