I’ve wired up a teensy 3.5 without a shield to 4 x 64 * 32 panels, but I’m getting some unwanted image distortion ( the image kinda blurs off to the side). Is this due to the absence of 5V level shifters? . longer ribbon cables and more screens seem to increase the distortion.
If I add in some level shifters would that sort this out? Are other elements of the smart matrix shield also required?
Just to note, some Teensy’s aren’t even 5V tolerant!
All ARM Teensys use 3.3 volts as their native voltage. Some Teensys (LC, 3.0, 3.6, 4.0, and 4.1) can be damaged if they get more than 3.3 volts on any pin, while other Teensys (3.1, 3.2, and 3.5) will tolerate 5 volt input for the digital pins (the analog only pins and the reset, program pins cannot tolerate anything more than 3.3 volts). To be compatible, no Teensy pin except for VIN and VUSB must ever get more than 3.3 volts;
