. It has a Teensy 3.6 on it with 5v attached to both the smartmatrix and the 64x64 display.
I did change a couple lines of code to define the 64x64 matrix. Here are the relevant lines:
#define COLOR_DEPTH 24 // known working: 24, 48 - If the sketch uses type rgb24 directly, COLOR_DEPTH must be 24
const uint8_t kMatrixHeight = 64; // known working: 16, 32, 48, 64
const uint8_t kPanelType = SMARTMATRIX_HUB75_64ROW_MOD32SCAN; // use SMARTMATRIX_HUB75_16ROW_MOD8SCAN for common 16x32 panels, or use SMARTMATRIX_HUB75_64ROW_MOD32SCAN for common 64x64 panels
const uint8_t kMatrixOptions = (SMARTMATRIX_OPTIONS_NONE); // see SmartMatrix - Overview for options
#include <SmartLEDShieldV4.h> // comment out this line for if you’re not using SmartLED Shield V4 hardware (this line needs to be before #include <SmartMatrix3.h>) #include <SmartMatrix3.h> #include “colorwheel.c” #include “gimpbitmap.h”
In the picture you will see the green and yellow wires are not connected to anything. Where are they supposed to be connected?
The ribbon cable needs to be plugged in to the top of the board, there’s photos in the instructions.
The yellow and green wires are only used for driving APA102 LEDs, “You may want to cut the ends off or tape over the exposed JST SM cable green/yellow wires to avoid causing shorts”
In my defense I guess all I can say is after making thousands of connections in my electronics life, I plugged the cable into the connector as one would normally expect and didn’t read the cable plugging instruction.
Thank you for your help on this and it is working fine now.
