good,
led panels with icn2037 or icn2038 work on teensy 3.2 ?
good,
The donated panel I got isnāt an ABC panel, so Iām still looking for a sample. If anyone has a known ABC panel that they want to sell or donate to me to help with adding this feature to SmartMatrix Library, Iād be grateful!
Iām in the UK now but family from the US will be visiting me in March, so I could give a US shipping address if that would make things easier for any US residents. Please send me a DM or email: hello@pixelmatix.com
and as luck would have it, the new ABC panels I bought ended up being ABCDE, so I donāt have spares I can send you either, sorry.
Hello everybody, someone knows difference beetween FM6124S and TC5020AP?
good, who chip have to have the led panels to give teensy 3.2 ?
Hello this is my first post. I am seekeing for informations about FM6126 init sequence: I donāt need any source code, but only the timing diagram and any trick not mentioned on the datasheet.
Some time ago I had the same problem with Sumacroās drivers and managed to get in touch with their engineers, that gave me support sending me all the needed infos. In this case I was unable to do the same thing with Fumanās engineers.
Anyone can help me ? Thanks in advance.
Sorry, I think a lot of people are interested in that info, but it doesnāt seem to be publicly available
Not sure if you have found it but here will help FM6126 datasheet (is on Chinese) but timing is there
FM2616A is supposed to be supported by the library now (it an option to give when you init the panel)
I have found a seller who claims he has FM6124 controlled panels, but on the silkscreen I see they are using only A and B. Do you think it will work with SmartMatrix?
No, last I checked SmartMatrix does not support AB panels, but they might work with rpi-rgb-panel
Likely yes, those panels are usually 2S/MOD2 or 4S/MOD4 and 2S only needs 1 address line, 4S needs 2 address lines. See this in the wiki:
I havenāt seen a P10 HUB75 panel that isnāt compatible with SmartMatrix Library, but there could still be issues
