Hi all,
I’ve been playing around with the SmartMatrix for a while now, and it’s been fun! However, I wondered if there was a good Teensy-based graphics library that would allow 2D/3D graphics to be rendered on the SmartMatrix. And I found that there was! I haven’t seen it mentioned in the forums here, but I thought I’d share it in case someone else found it useful (apologies if you have already covered this, or if it’s common knowledge).
The library is available here: https://github.com/vindar/tgx
I didn’t write the library, nor do I have any relation to the author(s), and all credit must go to them.
I put together the code below for you to try it out, and it’s heavily based on the Teensy 4 3D borg_cube example from the library. It renders a rotating cube with a constantly changing texture created in real-time (see image below). The changes required to make it work with SmartMatrix were pretty minimal:
- Remove all the references to the TFT display that the example uses
- Resize the frame buffers for the display size (128 x 128 in my case)
- Change the colour depth from RGB565 to RGB24
- Use memcpy to copy the rendering frame buffer to the SmartMatrix frame buffer (I could write directly to the SM frame buffer, but I wanted to keep it as close to the example as possible).
On a Teensy 4.1, I’m getting consistent 159 FPS, which is very impressive I think! I believe it should work on other set-ups just by changing the SM parameters at the top of the file. There are other examples that come with the library if anyone wants to experiment with it.
I hope that’s of interest to anyone.
welshcoder
The code:
#include <Arduino.h>
#include <tgx.h>
#include <font_tgx_OpenSans_Bold.h>
const uint16_t kMatrixWidth = 128; // Set to the width of your display, must be a multiple of 8
const uint16_t kMatrixHeight = 128; // Set to the height of your display
const uint8_t kPanelType = SM_PANELTYPE_HUB75_64ROW_MOD32SCAN; // Choose the configuration that matches your panels. See more details in MatrixCommonHub75.h and the docs: https://github.com/pixelmatix/SmartMatrix/wiki
const uint32_t kMatrixOptions = ( SM_HUB75_OPTIONS_BOTTOM_TO_TOP_STACKING); //(SM_HUB75_OPTIONS_NONE); // see docs for options: https://github.com/pixelmatix/SmartMatrix/wiki
const int defaultBrightness = 254; // full (100%) brightness
//const int defaultBrightness = (15*255)/100; // dim: 15% brightness
const rgb24 defaultBackgroundColor = {0x00, 0, 0};
// Teensy 4.0 has the LED on pin 13
const int ledPin = 13;
using namespace std;
// let's not burden ourselves with the tgx:: prefix
using namespace tgx;
// screen dimension (landscape mode)
static const int SLX = kMatrixWidth;
static const int SLY = kMatrixHeight;
// main screen framebuffer (48K in DTCM for fastest access)
RGB24 fb[SLX * SLY];
// zbuffer (64K in DMAMEM)
DMAMEM float zbuf[SLX * SLY];
// image that encapsulates the framebuffer fb.
Image<RGB24> im(fb, SLX, SLY);
// the texture image
const int tex_size = 128;
RGB24 texture_data[tex_size*tex_size];
Image<RGB24> texture(texture_data, tex_size, tex_size);
// 3D mesh drawer : using perspective projection.
Renderer3D<RGB24, SLX, SLY, true, false> rendererP;
// 3D mesh drawer : using orthoscopic projection.
Renderer3D<RGB24, SLX, SLY, true, true> rendererO;
// the cube 8 vertices
fVec3 tab_vertices[8] =
{-1,-1,1},
{1,-1,1},
{1,1,1},
{-1,1,1},
{-1,-1,-1},
{1,-1,-1},
{1,1,-1},
{-1,1,-1}
// texture indices
fVec2 tab_tex[4] =
{0.0f, 0.0f},
{1.0f, 0.0f},
{1.0f, 1.0f},
{0.0f, 1.0f},
// list of quads.
uint16_t vert_ind[6 * 4] =
0, 1, 2, 3, // front
1, 5, 6, 2, // right
5, 4, 7, 6, // back
4, 0, 3, 7, // left
0, 4, 5, 1, // bottom
3, 2, 6, 7 // top
// use the same texture on each quad
uint16_t tex_ind[6 * 4] =
0, 1, 2, 3,
0, 1, 2, 3,
0, 1, 2, 3,
0, 1, 2, 3,
0, 1, 2, 3,
0, 1, 2, 3
// the setup() method runs once, when the sketch starts
pinMode(ledPin, OUTPUT);
Serial.begin(115200);
// clear screen
const float ratio = ((float)SLX) / SLY;
// setup the 3D renderer with perspective projection
rendererP.setOffset(0, 0);
rendererP.setImage(&im);
rendererP.setZbuffer(zbuf, SLX * SLY);
rendererP.setPerspective(45, ratio, 0.1f, 1000.0f);
rendererP.setCulling(1);
rendererP.useBilinearTexturing(true);
// setup the 3D renderer with orthoscopic projection
rendererO.setOffset(0, 0);
rendererO.setImage(&im);
rendererO.setZbuffer(zbuf, SLX * SLY);
rendererO.setOrtho(-1.8*ratio, 1.8 *ratio, -1.8, 1.8, 0.1f, 1000.0f);
rendererO.setCulling(1);
rendererO.useBilinearTexturing(true);
// initial textrure color
texture.fillScreen(RGB565_Blue);
/** draw a random rectangle on the texture */
void splash()
static int count = 0;
static RGB565 color;
if (count == 0)
color = RGB565((int)random(32), (int)random(64), (int)random(32));
count = (count + 1) % 400;
iVec2 pos(random(tex_size), random(tex_size));
int r = random(10);
texture.drawRect(iBox2( pos.x - r, pos.x + r, pos.y - r, pos.y + r ), color);
/** draw the current fps on the image */
void fps(const char* str)
static elapsedMillis em = 0; // number of milli elapsed since last fps update
static int fps = 0; // last fps
static int count = 0; // number of frames since the last update
// recompute fps every second.
count++;
if ((int)em > 1000)
em = 0;
fps = count;
count = 0;
// display
//im.drawText(str, {3,12 }, RGB565_Red, font_tgx_OpenSans_Bold_10, false);
char buf[10];
sprintf(buf, "%d FPS", fps);
auto B = im.measureText(buf, { 0,0 }, font_tgx_OpenSans_Bold_10, false);
im.drawText(buf, { SLX - B.lx() - 3,12 }, RGB565_Red, font_tgx_OpenSans_Bold_10, false);
elapsedMillis em = 0; // time
int nbf = 0; ; // number frames drawn
int projtype = 0; // current projection used.
void loop()
// model matrix
fMat4 M;
M.setRotate(em / 11.0f, { 0,1,0 });
M.multRotate(em / 23.0f, { 1,0,0 });
M.multRotate(em / 41.0f, { 0,0,1 });
M.multTranslate({ 0, 0, -5 });
if (projtype)
im.fillScreen(RGB565_Black); // erase the screen
rendererP.clearZbuffer(); // clear the z buffer
rendererP.setModelMatrix(M);// position the model
rendererP.drawQuads(TGX_SHADER_TEXTURE, 6, vert_ind, tab_vertices, nullptr, nullptr, tex_ind, tab_tex, &texture); // draw !
fps("Perspective projection"); // overlay some infos
else
im.fillScreen(RGB565_Gray); // erase the screen
rendererO.clearZbuffer();
rendererO.setModelMatrix(M);
rendererO.drawQuads(TGX_SHADER_TEXTURE, 6, vert_ind, tab_vertices, nullptr, nullptr, tex_ind, tab_tex, &texture); // draw !
fps("Orthoscopic projection"); // overlay some infos
// update the screen (async).
memcpy(backgroundLayer.getRealBackBuffer(),fb,sizeof(fb));
// add a random rect on the texture.
splash();
// swith between perspective and orthogonal projection every 1000 frames.
if (nbf++ % 1000 == 0)
projtype = 1 - projtype;
/** end of file */
