I m using this ESP32 adapter (pic below) and got it working with the DMA this library
( confirmed no issues with wiring )
When trying with SmartMatrix libs, I got a noisy background layer as per the 2nd pic below , I can see the scrolling text working fine…
Here are my settings, everything else is as default…
Any hints or pointers on how to troubleshoot or fix this noisy background ???
Thanks for reading this message …
#include "MatrixHardware_Custom.h" // Copy an existing MatrixHardware file to your Sketch directory, rename, customize, and you can include it like this
const uint16_t kMatrixWidth = 64; // Set to the width of your display, must be a multiple of 8
const uint16_t kMatrixHeight = 64; // Set to the height of your display
const uint8_t kPanelType = SM_PANELTYPE_HUB75_64ROW_MOD32SCAN; // Choose the configuration that matches your panels. See more details in MatrixCommonHub75.h and the docs: https://github.com/pixelmatix/SmartMatrix/wiki
