This is my first use of a matrix display. Here are the hardware parts being used:
SmartMatrix SmartLED Shield (V4) for Teensy
64x64 RGB LED Matrix - 3mm Pitch
Teensy 3.6
I want to confirm how the Teensy 3.6 fits into the Shield. The shield has a side with 3 large connectors and the other side has 2 large IC’s on it. If the marking on the Teensy and the shield are all correct, the Teensy will plug into the shield from the side OPPOSITE the 3 big connectors. That seems counter intuitive to me.
Can someone confirm that is the correct way to assemble these two parts?
