I’ve tried to upload the on AnimatedGIFs on the Shield v.4 using a Teensy 3.6. I see others have had problems with this, as well. I tried to comment out other place. I think the relevant code that I’m not getting right is this
// Chip select for SD card on the SmartMatrix Shield or Photon
#if defined(ESP32)
#define SD_CS 5
#elif defined (ARDUINO)
#define SD_CS 15
//#define SD_CS BUILTIN_SDCARD
#elif defined (SPARK)
#define SD_CS SS
#if defined(ESP32)
// ESP32 SD Library can't handle a trailing slash in the directory name
#define GIF_DIRECTORY "/gifs"
#else
// Teensy SD Library requires a trailing slash in the directory name
#define GIF_DIRECTORY "/gifs/"
I tried commenting out:`
#define SD_CS 15
and uncommenting:
Everything compiled and uploaded nicely until I changed the commenting. When I changed the commenting, I got the following errors:
Arduino: 1.8.10 (Linux), TD: 1.48, Board: "Teensy 3.6, Serial, 180 MHz, Faster, US English"
AnimatedGIFs: In function 'void setup()':
AnimatedGIFs:127: error: 'BUILTIN_SDCARD' was not declared in this scope
/home/michael/Documents/Michael Davis/arduino/AnimatedGIFs/AnimatedGIFs.ino:203:19: note: in expansion of macro 'SD_CS'
if(initSdCard(SD_CS) < 0) {
Multiple libraries were found for "SmartLEDShieldV4.h"
Used: /home/michael/Documents/Michael
Multiple libraries were found for "SD.h"
Not used: /home/michael/Arduino-1.8.10/libraries/SD
Not used: /home/michael/Arduino-1.8.10/hardware/teensy/avr/libraries/SD
Multiple libraries were found for "SPI.h"
Used: /home/michael/Arduino-1.8.10/hardware/teensy/avr/libraries/SPI
"Show verbose output during compilation"
option enabled in File -> Preferences.
