I’ve also released and uploaded version 1.2 of SmartMatrix::GFX to github and the arduino library manager. Hopefully the dependency I put on ‘SmartMatrix’ instead of ‘SmartMatrix3’ will make things “just work” (didn’t really test this since I work out of git instead of the arduino library manager).
I’m not sure what will happen right now, as there is no library named SmartMatrix in Arduino Library Manager, but in the next week or so when SmartMatrix3 gets renamed to SmartMatrix, then hopefully it will just work
This code is a little simple and doesn’t take into account that there are more than two relevant hardware definitions now, but it’s in the sketch and can be edited easily to choose between other definitions, so it’s probably no big deal.
Thanks for the reply. I think you’re saying that SmartMatrix3 will disappear then?
In an ideal world, my old lib would have depended on your old lib, and my new lib would have depended on your new lib, but that’s probably overkill. People should just switch to the new one
As for the ifdef, yes, it’s very simplistic, it’s just a “works for me” template. Obviously I can’t guess what shield people are using and they’ll need to adjust accordingly.
I tested SmartMatrix::GFX installation with Arduino Library Manager (I also normally use git), and it fails when I try to update and have it install dependencies. If I try again and install just the library, it works. I’m going to be submitting the rename request shortly, so hopefully this is a short lived issue.
Library is already installed: Framebuffer GFX:1.0.0
Library is already installed: FastLED:3.3.3
Library is already installed: Adafruit GFX Library:1.10.0
Library is already installed: Adafruit BusIO:1.3.3
no protocol:
java.lang.RuntimeException: java.net.MalformedURLException: no protocol:
at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onInstallPressed$4(LibraryManagerUI.java:248)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.net.MalformedURLException: no protocol:
at java.net.URL.<init>(URL.java:611)
at java.net.URL.<init>(URL.java:508)
at java.net.URL.<init>(URL.java:457)
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:64)
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:60)
at cc.arduino.contributions.libraries.LibraryInstaller.performInstall(LibraryInstaller.java:155)
at cc.arduino.contributions.libraries.LibraryInstaller.install(LibraryInstaller.java:125)
at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onInstallPressed$4(LibraryManagerUI.java:237)
... 1 more
thanks for the heads up. Hopefully this indeed gets fixed when your rename goes through. Please let me know if not, and I’ll look into what needs to be fixed.
It’s been two weeks since the last batch of Arduino Library Manager requests were processed, so I hope that means they are close to doing the next batch:
“SmartMatrix3” is now renamed to “SmartMatrix” in Arduino Library Manager. I tested installing your library using Arduino Library Manager and the install is now smooth.
