Hi pixel mates !
I’ve just bought a teensy 4.1 and the SmartLed shield (v5) from pixelmatix.
Aurora seems a very nice project, but it has been developped for Teensy 3.1.
After a whole night compiling again and again my teensy, I could finally make it work !! I share what I’ve done :
I’ve trashed the file JumpToAppWithOffset.c which is designed for Teensy 3.1.
I’ve also renamed time in all the project by timexx due to this error : 'tmElements_t time' redeclared as different kind of symbol
I had display errors : https://photos.app.goo.gl/TXDymSYDVL3cFtAW7 but this was because the SD card pin was not correct…I have edited the hardware.h file, to #define SD_CARD_CS BUILTIN_SDCARD
Now I get the welcome display (“Patterns…”) when SD card is not present (sdAvailable = SD.begin(SD_CARD_CS); <0), but the teensy crashes when the SD card is present…Any idea ?
I don’t know, but I looked at the code and it seems like it should use a default value and not crash if the file can’t be found.
What resolution are you running. The Teensy 4 allows for larger resolution but Aurora is using an old GIF decoding library which may fail with large resolutions
Hi Louis,
I tried with 128x64, and also with 32x32, following your answer…
Same behavior…
I was maybe thinking of a wrong access to SD card, in read only maybe…so the file can’t be created…
Will investigate later.
Thanks for your support !
const uint8_t kMatrixWidth = 32; // known working: 32, 64, 96, 128
const uint8_t kDmaBufferRows = 2; // known working: 2-4, use 2 to save memory, more to keep from dropping frames and automatically lowering refresh rate
const uint8_t kPanelType = SM_PANELTYPE_HUB75_32ROW_MOD16SCAN; // Choose the configuration that matches your panels. See more details in MatrixCommonHub75.h and the docs: https://github.com/pixelmatix/SmartMatrix/wiki
Hi, I haven’t tested as I don’t have the EQ Breakout Board, I’m just stuck at the first screen, but it seems nothing won’t load from my SD card, due to library incompatibilities…
Hey @sebbie47 I’m a ling time user of the OG smartmatrix and just purchased a Teensy 4, the v5 SmartLED shield and a 64x64 matrix, and, just like you, discovered nothing compiles :-/
Where did you get to with making this work?
I’m currently fighting with SmartMatrix_Impl.h:37:30: error: 'F_BUS' was not declared in this scope #define TIMER_FREQUENCY (F_BUS/2)
