I am trying to upgrade from Teensy 3.5 to a Teensy 4.1. I have a custom shield that uses SmartMatrix4 Running the FeatureDemo.ino, works fine on the 3.5, but I get a blank screen on the Teensy 4.1. The hardware configuration files are quite a bit different, with the 4.1 using FlexIO. I have attached both 3.5 and 4.1 configuration files, along with the features demo.
Any help would be appreciated – Thanks
Attached is the matrix hardware configuration for the working 3.5 (modified version of MatrixHardware_Teensy3_ShieldV1toV3.h). here are the pins that I use:
#ifndef MATRIX_HARDWARE_H
#define MATRIX_HARDWARE_H
#pragma message "MatrixHardware: SmartMatrix Shield for Teensy 3.5 CoinOp"
#define COLOR_CHANNELS_PER_PIXEL 3
#define PIXELS_UPDATED_PER_CLOCK 2
#define DMA_UPDATES_PER_CLOCK
/* an advanced user may need to tweak these values */
// size of latch pulse - all address updates must fit inside high portion of latch pulse
// increase this value if DMA use is causing address updates to take longer
#define LATCH_TIMER_PULSE_WIDTH_NS 438
// max delay from rising edge of latch pulse to falling edge of clock
// increase this value if DMA use is delaying clock
// using largest delay seen at slowest supported clock speed (48MHz) 1400ns, saw 916ns at 96MHz
#define LATCH_TO_CLK_DELAY_NS 1400
// measured <3400ns to transfer 32 pixels at 96MHz, <6600ns to transfer 32 pixels at 48MHz
// for now, until DMA sharing complications (brought to light by Teensy 3.6 SDIO) can be worked out, enable DMA Bandwidth Control, which approximately doubles this estimated time
#define PANEL_32_PIXELDATA_TRANSFER_MAXIMUM_NS (uint32_t)((2 * 3400 * 96000000.0) / F_CPU)
/* this section describes how the microcontroller is attached to the display */
// these defines map the HUB75 signal to PORTD signals - if your panel has non-standard RGB order, swap signals here
#define BIT_0_SIGNAL hub75_r0
#define BIT_1_SIGNAL hub75_clk
#define BIT_2_SIGNAL hub75_g1
#define BIT_3_SIGNAL pad
#define BIT_4_SIGNAL hub75_b0
#define BIT_5_SIGNAL hub75_b1
#define BIT_6_SIGNAL hub75_r1
#define BIT_7_SIGNAL hub75_g0
//#define DEBUG_PINS_ENABLED
#define DEBUG_PIN_1 17
#define DEBUG_PIN_2 18
#define DEBUG_PIN_3 19
/************ The below definitions are unlikely to be useful if changed **************/
// these pin definitions are used to set GPIO to output, and are manually used to reset FM6126A panels - swapping RGB pins here has no effect on refreshing the panel
#define GPIO_PIN_CLK_TEENSY_PIN 14
#define GPIO_PIN_B0_TEENSY_PIN 6
#define GPIO_PIN_R0_TEENSY_PIN 2
#define GPIO_PIN_R1_TEENSY_PIN 21
#define GPIO_PIN_G0_TEENSY_PIN 5
#define GPIO_PIN_G1_TEENSY_PIN 7
#define GPIO_PIN_B1_TEENSY_PIN 20
#define GPIO_PIN_LATCH_TEENSY_PIN 3
#define GPIO_PIN_OE_TEENSY_PIN 4
#define ADDX_PIN_0 3
#define ADDX_PIN_1 0
#define ADDX_PIN_2 1
#define ADDX_PIN_3 2
#define ADDX_PIN_MASK ((1 << ADDX_PIN_0) | (1 << ADDX_PIN_1) | (1 << ADDX_PIN_2) | (1 << ADDX_PIN_3))
#define ADDX_TEENSY_PIN_0 9
#define ADDX_TEENSY_PIN_1 15
#define ADDX_TEENSY_PIN_2 22
#define ADDX_TEENSY_PIN_3 23
#define ADDX_GPIO_SET_REGISTER GPIOC_PSOR
#define ADDX_GPIO_CLEAR_REGISTER GPIOC_PCOR
#define SMARTLED_APA_ENABLED_BY_DEFAULT false
#define SMARTLED_APA_ENABLE_PIN 17
#define SMARTLED_APA_CLK_PIN 13
#define SMARTLED_APA_DAT_PIN 7
#define GPIO_WORD_ORDER_8BIT BIT_0_SIGNAL:1, BIT_1_SIGNAL:1, BIT_2_SIGNAL:1, BIT_3_SIGNAL:1, BIT_4_SIGNAL:1, BIT_5_SIGNAL:1, BIT_6_SIGNAL:1, BIT_7_SIGNAL:1
// output latch signal on pin 3 (PORTA.12), latch signal must be connected to pin 8 (PORTD.3) externally
#define ENABLE_LATCH_PWM_OUTPUT() { \
CORE_PIN3_CONFIG |= PORT_PCR_MUX(3) | PORT_PCR_DSE | PORT_PCR_SRE; \
// output OE signal on pin 4 (PORTA.13)
#define ENABLE_OE_PWM_OUTPUT() { \
CORE_PIN4_CONFIG = PORT_PCR_MUX(3) | PORT_PCR_DSE | PORT_PCR_SRE; \
// pin 3 (PORTA.12) triggers based on latch signal, on rising edge
#define ENABLE_LATCH_RISING_EDGE_GPIO_INT() { \
CORE_PIN3_CONFIG |= PORT_PCR_IRQC(1); \
#define DMAMUX_SOURCE_LATCH_RISING_EDGE DMAMUX_SOURCE_PORTA
// pin 8 (PORTD.3) is set to input, and triggers based on latch signal, on falling edge
#define ENABLE_LATCH_FALLING_EDGE_GPIO_INT() { \
CORE_PIN8_CONFIG |= PORT_PCR_MUX(1) | PORT_PCR_IRQC(2); \
#define DMAMUX_SOURCE_LATCH_FALLING_EDGE DMAMUX_SOURCE_PORTD
#else
#pragma GCC error "Multiple MatrixHardware*.h files included"
indent preformatted text by 4 spaces
This is the 4.1 hardware configuration. (modified version of MatrixHardware_Teensy4_ShieldV0.h):
#pragma message "MatrixHardware: SmartLED Shield for Teensy 4 V0"
// size of latch pulse - can be short for V4 shield which doesn't need to update ADDX lines during latch pulse
// 20 is minimum working value on DP5020B panel
// set to 100 for improved support with FM6126A panel
// don't exceed 150 to avoid interference between latch and data transfer
#define LATCH_TIMER_PULSE_WIDTH_NS 100
// max delay from rising edge of latch pulse to falling edge of first pixel clock
// Measured 220 ns delay at 600 MHz clock speed, 160 ns at 816 MHz. Slower speeds are not supported.
// Using larger delay for safety.
#define LATCH_TO_CLK_DELAY_NS 400
// Pixel clock frequency is generated using the 480 MHz PLL3 clock and a divide-by-n counter. Frequency is independent of CPU clock speed.
// Must increment divider value by 2 (division ratio is always even)
// Minimum tested working value is 20 (corresponding to 24 MHz clock frequency) on DP5020B panel
// Using value of 26 (corresponding to 18.462 MHz clock frequency) to improve stability and reduce glitching
// Larger values may be more stable, but will decrease maximum refresh rate
#define FLEXIO_CLOCK_DIVIDER 26
// Amount of time required to transfer 32 pixels
// Adding 200 ns overhead time to improve stability
#define PANEL_32_PIXELDATA_TRANSFER_MAXIMUM_NS ((32*FLEXIO_CLOCK_DIVIDER*1000/480) + 200)
// these defines control the color channel assignments - if your panel has non-standard RGB order, swap signals here
#define R_0_SIGNAL FLEXIO_PIN_R0_TEENSY_PIN
#define G_0_SIGNAL FLEXIO_PIN_G0_TEENSY_PIN
#define B_0_SIGNAL FLEXIO_PIN_B0_TEENSY_PIN
#define R_1_SIGNAL FLEXIO_PIN_R1_TEENSY_PIN
#define G_1_SIGNAL FLEXIO_PIN_G1_TEENSY_PIN
#define B_1_SIGNAL FLEXIO_PIN_B1_TEENSY_PIN
// active pin number definitions
// data bit order is calculated in setup using the pin number definitions and color channel assignments
// these pin definitions are also manually used to reset FM6126A panels
#define FLEXPWM_PIN_OE_TEENSY_PIN 4
#define FLEXPWM_PIN_LATCH_TEENSY_PIN 3
#define FLEXIO_PIN_CLK_TEENSY_PIN 14
#define FLEXIO_PIN_CLK_TEENSY_PIN_ALT 14
#define FLEXIO_PIN_B0_TEENSY_PIN 6
#define FLEXIO_PIN_R0_TEENSY_PIN 2
#define FLEXIO_PIN_R1_TEENSY_PIN 21
#define FLEXIO_PIN_G0_TEENSY_PIN 5
#define FLEXIO_PIN_G1_TEENSY_PIN 7
#define FLEXIO_PIN_B1_TEENSY_PIN 20
#define FLEXIO_PIN_APA102_CLK 13
#define FLEXIO_PIN_APA102_DAT 7
#define ADDX_0_SIGNAL FLEXIO_PIN_R0_TEENSY_PIN
#define ADDX_1_SIGNAL FLEXIO_PIN_G0_TEENSY_PIN
#define ADDX_2_SIGNAL FLEXIO_PIN_B0_TEENSY_PIN
#define ADDX_3_SIGNAL FLEXIO_PIN_R1_TEENSY_PIN
#define ADDX_4_SIGNAL FLEXIO_PIN_G1_TEENSY_PIN
#else
Finally here is the FeatureDemo.ino configuration section
//#define USE_ADAFRUIT_GFX_LAYERS
#include <MatrixHardware_COINOP_TEENSY_4_1.h>
#include <SmartMatrix4.h>
const uint16_t kMatrixWidth = 128; // Set to the width of your display, must be a multiple of 8
const uint16_t kMatrixHeight = 32; // Set to the height of your display
const uint8_t kRefreshDepth = 24; // Tradeoff of color quality vs refresh rate, max brightness, and RAM usage. 36 is typically good, drop down to 24 if you need to. On Teensy, multiples of 3, up to 48: 3, 6, 9, 12, 15, 18, 21, 24, 27, 30, 33, 36, 39, 42, 45, 48. On ESP32: 24, 36, 48
const uint8_t kPanelType = SMARTMATRIX_HUB75_32ROW_MOD16SCAN; // Choose the configuration that matches your panels. See more details in MatrixCommonHub75.h and the docs: https://github.com/pixelmatix/SmartMatrix/wiki
