So I have been poking at these fadecandy ports for several months on and off now.
I can’t get the fadecandy server to find either a teensy4 with v5 shield or a teensy3.2 with a shield meant for a 3.1 teensy. Either combination works fine as is, once I get them configured. I have been trying to build the server for ubuntu, and keep getting some libudev errors [iirc]. Any advice getting this up and running on a system that isn’t a mac? Thanks
[I meant to reply to this post so deleted the other one]
Are you using the modified Fadecandy Server that has support for SmartMatrix?
I don’t know what you mean by this
Can you build the normal Fadecandy server? If you post what you’ve tried and the result, maybe I can give feedback, but I don’t typically use Linux and haven’t tried compiling so I have no advice out of the gate
Sorry if it was not clear, I updated my other post to say that I could build the fadecandy normal server on linux.
Trying again in windows. I push the Fadecandy_T4 to a Teensy 4.0, and ran the fcserver.exe Teensy4.json in a admin terminal, still doesnt see it. The T4 shows up with dual serial in Arduino, vs one, so I know it pushed properly…
I made a new thread as this was getting off topic for the general Teensy 4 thread.
Are you able to build this modified Fadecandy Server in Windows? (The normal Fadecandy Server, or any precompiled binaries you might find won’t have the SmartMatrix modifications)
I was looking through your repo and I was not sure exactly you were up to in order to incorporate support. Sometimes cs stuff gets lost on me, as I do code, but I am more of a hardware nut - thats why this is fascinating to me. I like learning about this, its just a little up there for me since fadecandy is a established piece of software.
Maybe if you could outline for me, I could try to get that working in these other build environments?
I am able to see the teensy but not in the fadecandy server, and iirc the teensy in arduino ide said something about fadecandy after I flashed it. So I know it took. I was triple checking my usb cables and using diff (2.0/3.0) cabling also. No dice :
thank you! I was thinking about this when I left to go skate today, and was like “I could probably just diff on the repos and that would show me” … Thanks for pointing that out.
