Hi All,
I am having issues trying to get Aurora working, the Smartled V4 works without any issues using the demo files included with the library, but Aurora keeps crashing while trying to compile.
Arduino: 1.8.9 (Linux), TD: 1.47, Board: "Teensy 3.6, Serial, 180 MHz, Faster, US English"
In file included from /home/pi/Arduino/Aurora/Aurora.ino:64:0:
/home/pi/Arduino/libraries/FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.003.002
# pragma message "FastLED version 3.003.002"
In file included from /home/pi/Arduino/Aurora/Aurora.ino:73:0:
/home/pi/Arduino/libraries/aJson/aJSON.h:92:6: error: conflicting return type specified for 'virtual int aJsonStream::flush()'
int flush();
In file included from /opt/arduino-1.8.9/hardware/teensy/avr/cores/teensy3/Stream.h:24:0,
from /opt/arduino-1.8.9/hardware/teensy/avr/cores/teensy3/HardwareSerial.h:252,
from /opt/arduino-1.8.9/hardware/teensy/avr/cores/teensy3/WProgram.h:46,
from /tmp/arduino_build_228626/pch/Arduino.h:6:
/opt/arduino-1.8.9/hardware/teensy/avr/cores/teensy3/Print.h:62:15: error: overriding 'virtual void Print::flush()'
virtual void flush() { }
In file included from /home/pi/Arduino/Aurora/Aurora.ino:74:0:
/home/pi/Arduino/libraries/NoUseGifDecoder/GifDecoder.h: In member function 'virtual unsigned int Animations::drawFrame()':
GifDecoder.h:83: error: 'int GifDecoder<32, 32, 12>::frameDelay' is private
int frameDelay;
In file included from /home/pi/Arduino/Aurora/Aurora.ino:203:0:
Animations.h:95: error: within this context
return gifDecoder.frameDelay * 10;
/tmp/arduino_build_228626/sketch/Animations.h: In member function 'virtual void Animations::stop()':
Animations.h:103: error: 'fileClose' was not declared in this scope
fileClose();
In file included from /home/pi/Arduino/Aurora/Aurora.ino:229:0:
/tmp/arduino_build_228626/sketch/Settings.h: In member function 'void Settings::openImageFile()':
Settings.h:100: error: 'openGifFilename' was not declared in this scope
if(!openGifFilename(filepath))
/tmp/arduino_build_228626/sketch/Settings.h: In member function 'virtual void Settings::stop()':
Settings.h:153: error: 'fileClose' was not declared in this scope
fileClose();
GifDecoder.h: In function 'void drawPixelCallback(int16_t, int16_t, uint8_t, uint8_t, uint8_t)':
GifDecoder.h:69: error: 'int GifDecoder<32, 32, 12>::lsdWidth' is private
int lsdWidth;
Aurora:278: error: within this context
if (gifDecoder.lsdWidth == 32 && gifDecoder.lsdHeight == 32) {
GifDecoder.h:70: error: 'int GifDecoder<32, 32, 12>::lsdHeight' is private
int lsdHeight;
/home/pi/Arduino/Aurora/AnimatedGIFs.ino: At global scope:
AnimatedGIFs:91: error: redefinition of 'const uint8_t kMatrixWidth'
const uint8_t kMatrixWidth = 32; // known working: 32, 64, 96, 128
/home/pi/Arduino/Aurora/Aurora.ino:31:15: note: 'const uint8_t kMatrixWidth' previously defined here
AnimatedGIFs:92: error: redefinition of 'const uint8_t kMatrixHeight'
/home/pi/Arduino/Aurora/Aurora.ino:32:15: note: 'const uint8_t kMatrixHeight' previously defined here
AnimatedGIFs:93: error: redefinition of 'const uint8_t kRefreshDepth'
/home/pi/Arduino/Aurora/Aurora.ino:33:15: note: 'const uint8_t kRefreshDepth' previously defined here
AnimatedGIFs:94: error: redefinition of 'const uint8_t kDmaBufferRows'
const uint8_t kDmaBufferRows = 2; // known working: 2-4
/home/pi/Arduino/Aurora/Aurora.ino:34:15: note: 'const uint8_t kDmaBufferRows' previously defined here
AnimatedGIFs:95: error: redefinition of 'const uint8_t kPanelType'
/home/pi/Arduino/Aurora/Aurora.ino:35:15: note: 'const uint8_t kPanelType' previously defined here
AnimatedGIFs:96: error: redefinition of 'const uint8_t kMatrixOptions'
/home/pi/Arduino/Aurora/Aurora.ino:36:15: note: 'const uint8_t kMatrixOptions' previously defined here
AnimatedGIFs:97: error: redefinition of 'const uint8_t kBackgroundLayerOptions'
/home/pi/Arduino/Aurora/Aurora.ino:37:15: note: 'const uint8_t kBackgroundLayerOptions' previously defined here
AnimatedGIFs:98: error: redefinition of 'const uint8_t kScrollingLayerOptions'
/home/pi/Arduino/Aurora/Aurora.ino:38:15: note: 'const uint8_t kScrollingLayerOptions' previously defined here
In file included from /home/pi/Arduino/libraries/SmartMatrix3/src/SmartLEDShieldV4.h:5:0,
from /tmp/arduino_build_228626/sketch/Hardware.h:23,
from /home/pi/Arduino/Aurora/Aurora.ino:25:
/home/pi/Arduino/libraries/SmartMatrix3/src/SmartMatrix3.h:155:249: error: redefinition of 'uint32_t matrixUpdateData [780]'
static DMAMEM uint32_t matrixUpdateData[buffer_rows * (pwm_depth/COLOR_CHANNELS_PER_PIXEL / sizeof(uint32_t)) * ((((width * height) / CONVERT_PANELTYPE_TO_MATRIXPANELHEIGHT(panel_type)) * DMA_UPDATES_PER_CLOCK + ADDX_UPDATE_BEFORE_LATCH_BYTES))]; \
/home/pi/Arduino/Aurora/AnimatedGIFs.ino:100:1: note: in expansion of macro 'SMARTMATRIX_ALLOCATE_BUFFERS'
/home/pi/Arduino/libraries/SmartMatrix3/src/SmartMatrix3.h:155:28: note: 'uint32_t matrixUpdateData [780]' previously declared here
/home/pi/Arduino/Aurora/Aurora.ino:79:1: note: in expansion of macro 'SMARTMATRIX_ALLOCATE_BUFFERS'
/home/pi/Arduino/libraries/SmartMatrix3/src/SmartMatrix3.h:156:281: error: redefinition of 'uint8_t matrixUpdateBlocks [500]'
static DMAMEM uint8_t matrixUpdateBlocks[(sizeof(matrixUpdateBlock) * buffer_rows * pwm_depth/COLOR_CHANNELS_PER_PIXEL) + (sizeof(addresspair) * CONVERT_PANELTYPE_TO_MATRIXROWSPERFRAME(panel_type)) + (sizeof(timerpair) * pwm_depth/COLOR_CHANNELS_PER_PIXEL) + sizeof(timerpair)]; \
/home/pi/Arduino/libraries/SmartMatrix3/src/SmartMatrix3.h:156:27: note: 'uint8_t matrixUpdateBlocks [500]' previously declared here
AnimatedGIFs:100: error: redefinition of 'SmartMatrix3<36, 32, 32, 0u, 0u> matrix'
/home/pi/Arduino/libraries/SmartMatrix3/src/SmartMatrix3.h:157:82: note: in definition of macro 'SMARTMATRIX_ALLOCATE_BUFFERS'
SmartMatrix3<pwm_depth, width, height, panel_type, option_flags> matrix_name(buffer_rows, matrixUpdateData, matrixUpdateBlocks)
/home/pi/Arduino/Aurora/Aurora.ino:79:30: note: 'SmartMatrix3<36, 32, 32, 0u, 0u> matrix' previously declared here
/home/pi/Arduino/libraries/SmartMatrix3/src/SmartMatrix3.h:157:70: note: in definition of macro 'SMARTMATRIX_ALLOCATE_BUFFERS'
/home/pi/Arduino/libraries/SmartMatrix3/src/SmartMatrix3.h:171:67: error: redefinition of 'rgb24 backgroundBitmap [2048]'
static RGB_TYPE(storage_depth) backgroundBitmap[2*width*height]; \
/home/pi/Arduino/Aurora/AnimatedGIFs.ino:101:1: note: in expansion of macro 'SMARTMATRIX_ALLOCATE_BACKGROUND_LAYER'
/home/pi/Arduino/libraries/SmartMatrix3/src/SmartMatrix3.h:171:36: note: 'rgb24 backgroundBitmap [2048]' previously declared here
/home/pi/Arduino/Aurora/Aurora.ino:80:1: note: in expansion of macro 'SMARTMATRIX_ALLOCATE_BACKGROUND_LAYER'
/home/pi/Arduino/libraries/SmartMatrix3/src/SmartMatrix3.h:172:86: error: redefinition of 'SMLayerBackground<rgb24, 0u> backgroundLayer'
static SMLayerBackground<RGB_TYPE(storage_depth), background_options> layer_name(backgroundBitmap, width, height)
/home/pi/Arduino/Aurora/Aurora.ino:80:39: note: 'SMLayerBackground<rgb24, 0u> backgroundLayer' previously declared here
/home/pi/Arduino/libraries/SmartMatrix3/src/SmartMatrix3.h:172:75: note: in definition of macro 'SMARTMATRIX_ALLOCATE_BACKGROUND_LAYER'
/home/pi/Arduino/libraries/SmartMatrix3/src/SmartMatrix3.h:161:59: error: redefinition of 'uint8_t scrollingLayerBitmap [128]'
static uint8_t layer_name##Bitmap[width * (height / 8)]; \
/home/pi/Arduino/Aurora/AnimatedGIFs.ino:103:1: note: in expansion of macro 'SMARTMATRIX_ALLOCATE_SCROLLING_LAYER'
/home/pi/Arduino/Aurora/Aurora.ino:81:38: note: 'uint8_t scrollingLayerBitmap [128]' previously declared here
/home/pi/Arduino/libraries/SmartMatrix3/src/SmartMatrix3.h:161:20: note: in definition of macro 'SMARTMATRIX_ALLOCATE_SCROLLING_LAYER'
AnimatedGIFs:103: error: redefinition of 'SMLayerScrolling<rgb24, 0u> scrollingLayer'
/home/pi/Arduino/libraries/SmartMatrix3/src/SmartMatrix3.h:162:84: note: in definition of macro 'SMARTMATRIX_ALLOCATE_SCROLLING_LAYER'
static SMLayerScrolling<RGB_TYPE(storage_depth), scrolling_options> layer_name(layer_name##Bitmap, width, height)
/home/pi/Arduino/Aurora/Aurora.ino:81:38: note: 'SMLayerScrolling<rgb24, 0u> scrollingLayer' previously declared here
/home/pi/Arduino/libraries/SmartMatrix3/src/SmartMatrix3.h:162:73: note: in definition of macro 'SMARTMATRIX_ALLOCATE_SCROLLING_LAYER'
AnimatedGIFs: In function 'void screenClearCallback()':
AnimatedGIFs:126: error: redefinition of 'void screenClearCallback()'
void screenClearCallback(void) {
/home/pi/Arduino/Aurora/Aurora.ino:269:6: note: 'void screenClearCallback()' previously defined here
AnimatedGIFs: In function 'void updateScreenCallback()':
AnimatedGIFs:130: error: redefinition of 'void updateScreenCallback()'
void updateScreenCallback(void) {
/home/pi/Arduino/Aurora/Aurora.ino:273:6: note: 'void updateScreenCallback()' previously defined here
AnimatedGIFs: In function 'void drawPixelCallback(int16_t, int16_t, uint8_t, uint8_t, uint8_t)':
AnimatedGIFs:134: error: redefinition of 'void drawPixelCallback(int16_t, int16_t, uint8_t, uint8_t, uint8_t)'
void drawPixelCallback(int16_t x, int16_t y, uint8_t red, uint8_t green, uint8_t blue) {
/home/pi/Arduino/Aurora/Aurora.ino:277:6: note: 'void drawPixelCallback(int16_t, int16_t, uint8_t, uint8_t, uint8_t)' previously defined here
AnimatedGIFs: In function 'void setup()':
AnimatedGIFs:139: error: redefinition of 'void setup()'
/home/pi/Arduino/Aurora/Aurora.ino:290:6: note: 'void setup()' previously defined here
void setup()
AnimatedGIFs: In function 'void loop()':
AnimatedGIFs:199: error: redefinition of 'void loop()'
/home/pi/Arduino/Aurora/Aurora.ino:446:6: note: 'void loop()' previously defined here
void loop()
Multiple libraries were found for "FastLED.h"
Used: /home/pi/Arduino/libraries/FastLED
Not used: /opt/arduino-1.8.9/hardware/teensy/avr/libraries/FastLED
Multiple libraries were found for "SD.h"
Used: /opt/arduino-1.8.9/hardware/teensy/avr/libraries/SD
Not used: /opt/arduino-1.8.9/libraries/SD
thanks for your help in advance!
