I’d like to add a thin plastic sheet in front of my RGBpanel to
protect the LEDs (I’ve already has one ripped off in transport)
be a bit larger than the panel so that I can round the corners and avoid my existing corners that will poke your eye out if you put it in the wrong place
maybe act as a small diffuser (so it would not be completely transparent).
be reasonably light/flexible but not break easily
With my neopixel panel, I actually only use tracing paper, which works fine, but wouldn’t act as a protective layer in the RGBpanel case, nor can it extend past the corners to add protection.
For the rear, I have the panel be inside my shirt and use the white shirt as a diffuser/protection, but that won’t work here either as the RGBpanel is too thick/pocky for me to want to wear it that close to my skin
So, some kind of plastic diffuser sheet on top of the panels is probably what’s best in my case. Any ideas?
(big bonus points for something I can order online of course)
I use Acrylite Satinice 1/8" 3mm sheets for most of my projects. You could put a rounded edge on them. They’re not flexible though, acrylic can be brittle.
I don’t have any appropriate samples to try, but I was thinking a translucent silicone mat might meet your criteria.
Here’s a picture of some thin packing foam from a recent Aliexpress order. It tears easily from the edge, so maybe not as robust as you’d need.
Think about layering something soft under something more rigid, like a clear file folder that will hold its shape, and potentially hold the diffuser in place.
Thanks for all the links, on that note, believe it or not, I’ve actually had non sober people bunch me (twice) for reasons I don’t understand. It wasn’t a huge punch, but enough to break something that’s brittle. Also, it needs to survive a plane flight, so it can’t be glass like
It is flexible and light enough (not super light, but it’s workable), and is probably what I will be using as protection.
To be honest, the diffusing effect is quite light unless I space the sheet a little bit away from the display. In other words, if I put it right on top, there is almost no diffusing effect, but maybe if I sand it, it’ll work better, or somehow if I can install some spacers…
Usually clear, so you’d need something else for diffusion
BOPP Film
This is really thin, translucent with light behind it, but completely opaque without, and transmits light well. I thought it looked great with a matrix behind it
It’s too thin to have any structure on its own, so you need to sandwich it between two other layers. I tried experimenting with using adhesive to attach it to acrylic but ended up with bubbles
I used this on my first SmartMatrix product that I sold at maker faire in 2014. It’s difficult to work with in large quantities, so I avoided it for future kits
Maybe try something used in professional lighting. These are called filter and come in sheets or on roll. One of them is called “frost”. You usually place it in front of a lamp to soften the light and reduce shadows. There are tons of different frost filter variations to choose from. Most known manufacturer may be Lee filters.
