I’m using a Teensy 3.2 and SmartShield v4 with two 64x32 panels from Adafruit.
If I set kMatrixWidth = 64 the panels are mirrored.
If I set kMatrixWidth = 128 the panels go black.
96 “works” by extending across displays, but mirroring the ends.
I’ve tried lowering color depth and buffer rows but that didn’t help.
Here are my options:
const uint8_t kMatrixWidth = 128; // known working: 32, 64, 96, 128
