It’s essentially the FeatureDemo #define USE_ADAFRUIT_GFX_LAYERS and #include <MatrixHardware_Teensy4_ShieldV5.h> uncommented. I believe the default constants kMatrixWidth, kMatrixHeight, and kPanelType are what I want to use.
SmartMatrix Features Demo - Louis Beaudoin (Pixelmatix)
This example code is released into the public domain
(New in SmartMatrix Library 4.0) To update a SmartMatrix Library sketch to use Adafruit_GFX compatible layers:
- Make sure you have the Adafruit_GFX Library installed in Arduino (you can use Arduino Library Manager)
- add `#define USE_ADAFRUIT_GFX_LAYERS` at top of sketch (this is needed for any sketch to tell SmartMatrix Library that Adafruit_GFX is present, not just this sketch)
- Add this *before* #include <SmartMatrix.h>
- Check the documentation Wiki for more details on why you may or may not want to use these layers
//#include <MatrixHardware_Teensy3_ShieldV4.h> // SmartLED Shield for Teensy 3 (V4)
//#include <MatrixHardware_Teensy3_ShieldV1toV3.h> // SmartMatrix Shield for Teensy 3 V1-V3
//#include <MatrixHardware_ESP32_V0.h> // This file contains multiple ESP32 hardware configurations, edit the file to define GPIOPINOUT (or add #define GPIOPINOUT with a hardcoded number before this #include)
//#include "MatrixHardware_Custom.h" // Copy an existing MatrixHardware file to your Sketch directory, rename, customize, and you can include it like this
const uint16_t kMatrixWidth = 32; // Set to the width of your display, must be a multiple of 8
const uint16_t kMatrixHeight = 32; // Set to the height of your display
const uint8_t kPanelType = SM_PANELTYPE_HUB75_32ROW_MOD16SCAN; // Choose the configuration that matches your panels. See more details in MatrixCommonHub75.h and the docs: https://github.com/pixelmatix/SmartMatrix/wiki
#ifdef USE_ADAFRUIT_GFX_LAYERS
// there's not enough allocated memory to hold the long strings used by this sketch by default, this increases the memory, but it may not be large enough
SMARTMATRIX_ALLOCATE_GFX_MONO_LAYER(scrollingLayer, kMatrixWidth, kMatrixHeight, 6*1024, 1, COLOR_DEPTH, kScrollingLayerOptions);
#else
#include "colorwheel.c"
#include "gimpbitmap.h"
const int defaultBrightness = (100*255)/100; // full (100%) brightness
//const int defaultBrightness = (15*255)/100; // dim: 15% brightness
const rgb24 defaultBackgroundColor = {0x40, 0, 0};
// Teensy 3.0 has the LED on pin 13
const int ledPin = 13;
