Any idea why this gif won’t play on my smartmatrix?
The matrix seems to play other gifs ok.
Cheers
Phil
Cheers
Phil
Not at the moment. Try using ezgif.com to reencode it
Is there a maximum size for the gif? I have a 64x64 pixel gif that is around 1.2mb.
It plays for about 1/3 of a second then stops.
In the past I’ve played an 8.2MB 64x64 GIF. Try reencoding the GIF you have using ezgif.com
I haven’t found a size limit. I have run several 32x64 abstract animations up to 10 hours long. The files range from 250 Mb to over 1 Gb. They seem to play fine as long as I set the timer accordingly.
