Hi,
I’m using ESP32 kit.
I’m using MQTT publisher and subscriber send the data from MQTT web is successful.
through ESP32 to MQTT is getting error like this.
[1B][0;32mI (235498) MQTT_Task: MQTT Data Length=262[1B][0m
DATA={
“Switch Status”: {
“DevSerialNumber”: “SS201803A000001”,
“DevID”: “SSB3F112345”,
“CurrOpMode”: 63,
“SwitchCount”: 0,
“MasterSW”: 3,
“SW1”: 129,
“SW2”: 12,
“SW3”: 129,
“FanCount”: 129,
“Fan1Ctl”: 1,
“Fan1Speed”: 129
}Ç[14][07]\M«û?Ыû?P[10][15]m[1C]Ð
Decoded data received from Mqtt server…
Guru Meditation Error: Core 1 panic’ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400d4522 PS : 0x00060130 A0 : 0x800d4934 A1 : 0x3ffcc710
A2 : 0x00000000 A3 : 0x3ffc0c5c A4 : 0x3ffca8a7 A5 : 0x0000001f
A6 : 0x00000001 A7 : 0x00000003 A8 : 0x800d4522 A9 : 0x3ffcc6f0
A10 : 0x00000000 A11 : 0x3f4043c0 A12 : 0x3ffb3e60 A13 : 0x3ffcc3e0
A14 : 0x3ffcc3e0 A15 : 0x00000002 SAR : 0x00000018 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000010 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xfffffff5
ELF file SHA256: b2d51f625e80ab2384c3765206447058bb4f71ac70197d3e640a9c6626f6dd48
Backtrace: 0x400d4522:0x3ffcc710 0x400d4931:0x3ffcc730 0x40164bc2:0x3ffcc750 0x400d5746:0x3ffcc770 0x400d5905:0x3ffcc7c0 0x400d5ac4:0x3ffcc7f0 0x4008db1d:0x3ffcc810
Rebooting…
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:6368
ho 0 tail 12 room 4
load:0x40078000,len:11624
ho 0 tail 12 room 4
load:0x40080400,len:6648
entry 0x40080764
[1B][0;32mI (32) boot: ESP-IDF v3.3-dirty 2nd stage bootloader[1B][0m
[1B][0;32mI (32) boot: compile time 17:32:33[1B][0m
[1B][0;32mI (33) boot: Enabling RNG early entropy source…[1B][0m
[1B][0;32mI (38) boot: SPI Speed : 40MHz[1B][0m
[1B][0;32mI (42) boot: SPI Mode : DIO[1B][0m
[1B][0;32mI (46) boot: SPI Flash Size : 4MB[1B][0m
[1B][0;32mI (50) boot: Partition Table:[1B][0m
[1B][0;32mI (53) boot: ## Label Usage Type ST Offset Length[1B][0m
[1B][0;32mI (61) boot: 0 nvs WiFi data 01 02 00009000 00004000[1B][0m
[1B][0;32mI (68) boot: 1 otadata OTA data 01 00 0000d000 00002000[1B][0m
[1B][0;32mI (76) boot: 2 phy_init RF data 01 01 0000f000 00001000[1B][0m
[1B][0;32mI (83) boot: 3 factory factory app 00 00 00010000 00100000[1B][0m
[1B][0;32mI (91) boot: 4 ota_0 OTA app 00 10 00110000 00100000[1B][0m
[1B][0;32mI (98) boot: 5 ota_1 OTA app 00 11 00210000 00100000[1B][0m
[1B][0;32mI (106) boot: End of partition table[1B][0m
[1B][0;32mI (110) boot: Defaulting to factory image[1B][0m
[1B][0;32mI (114) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x23af4 (146164) map[1B][0m
[1B][0;32mI (175) esp_image: segment 1: paddr=0x00033b1c vaddr=0x3ffb0000 size=0x030e4 ( 12516) load[1B][0m
[1B][0;32mI (180) esp_image: segment 2: paddr=0x00036c08 vaddr=0x40080000 size=0x00400 ( 1024) load[1B][0m
[1B][0;32mI (182) esp_image: segment 3: paddr=0x00037010 vaddr=0x40080400 size=0x09000 ( 36864) load[1B][0m
[1B][0;32mI (206) esp_image: segment 4: paddr=0x00040018 vaddr=0x400d0018 size=0x97118 (618776) map[1B][0m
[1B][0;32mI (423) esp_image: segment 5: paddr=0x000d7138 vaddr=0x40089400 size=0x074bc ( 29884) load[1B][0m
[1B][0;32mI (446) boot: Loaded app from partition at offset 0x10000[1B][0m
[1B][0;32mI (446) boot: Disabling RNG early entropy source…[1B][0m
[1B][0;32mI (446) cpu_start: Pro cpu up.[1B][0m
[1B][0;32mI (450) cpu_start: Application information:[1B][0m
[1B][0;32mI (455) cpu_start: Project name: Smart_Switch[1B][0m
[1B][0;32mI (460) cpu_start: App version: 1[1B][0m
[1B][0;32mI (465) cpu_start: Compile time: Dec 28 2020 17:32:43[1B][0m
[1B][0;32mI (471) cpu_start: ELF file SHA256: b2d51f625e80ab23…[1B][0m
[1B][0;32mI (477) cpu_start: ESP-IDF: v3.3-dirty[1B][0m
[1B][0;32mI (482) cpu_start: Starting app cpu, entry point is 0x40081160[1B][0m
[1B][0;32mI (472) cpu_start: App cpu up.[1B][0m
[1B][0;32mI (492) heap_init: Initializing. RAM available for dynamic allocation:[1B][0m
[1B][0;32mI (499) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM[1B][0m
[1B][0;32mI (505) heap_init: At 3FFB9978 len 00026688 (153 KiB): DRAM[1B][0m
[1B][0;32mI (512) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM[1B][0m
[1B][0;32mI (518) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM[1B][0m
[1B][0;32mI (524) heap_init: At 400908BC len 0000F744 (61 KiB): IRAM[1B][0m
[1B][0;32mI (531) cpu_start: Pro cpu start user code[1B][0m
[1B][0;32mI (213) cpu_start: Chip Revision: 1[1B][0m
[1B][0;33mW (214) cpu_start: Chip revision is higher than the one configured in menuconfig. Suggest to upgrade it.[1B][0m
[1B][0;32mI (217) cpu_start: Starting scheduler on PRO CPU.[1B][0m
[1B][0;32mI (0) cpu_start: Starting scheduler on APP CPU.[1B][0m
[1B][0;32mI (228) APP_MAIN: [APP] Startup…[1B][0m
[1B][0;32mI (228) APP_MAIN: [APP] Free memory: 271120 bytes[1B][0m
[1B][0;32mI (238) APP_MAIN: [APP] IDF version: v3.3-dirty[1B][0m
[1B][0;32mI (248) uart_com: [Mcu_UART_INIT]:[1B][0m
[1B][0;32mI (248) uart: queue free spaces: 50[1B][0m
[1B][0;32mI (248) Json: Creating JSON Structure…[1B][0m
Switch Master Status found: 254
Switch 1 Status found: 254
Switch 2 Status found: 254
Switch 3 Status found: 254
Fan 1 Status found: 254
Fan 1 Speed Level Status found: 254
Committing Switch Status in NVS … NVS Commit Switch Status Done
Reading Manufactring Data from NVS
Data stored in NVS for key: Serial_Num is: 1907SSB3F100001
Data stored in NVS for key: Dev_ID is: F112345
Data stored in NVS for key: MQTT_URL is: mqtt://122.166.163.105:1884
Data stored in NVS for key: OTA_URL is: https://moveonsmartswitch.s3.ap-south-1.amazonaws.com/Moveon_SmartSwitch.bin
Data stored in NVS for key: ESP_FRIM_VER is: 1
Manufactring Data found in NVS
STRCAT(Topic from SerialNum & DevID): 1907SSB3F100001F112345
[1B][0;32mI (368) SmartConfig: Entering Smart Config [1B][0m
[1B][0;32mI (378) SmartConfig: Smartconfig_fetch_wifi_sta_config: ssid:ABfortune5 password:ABfortune#22[1B][0m
[1B][0;32mI (388) APP_MAIN: Saved wifi found on startup. Will attempt to connect.[1B][0m
[1B][0;32mI (388) APP_MAIN: Saved SSID:ABfortune5 and PASSWORD:ABfortune#22[1B][0m
I (408) wifi: wifi driver task: 3ffc4d68, prio:23, stack:3584, core=0
[1B][0;32mI (408) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[1B][0m
[1B][0;32mI (418) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[1B][0m
I (448) wifi: wifi firmware version: aeed694
I (448) wifi: config NVS flash: enabled
I (448) wifi: config nano formating: disabled
I (448) wifi: Init dynamic tx buffer num: 32
I (458) wifi: Init data frame dynamic rx buffer num: 32
I (458) wifi: Init management frame dynamic rx buffer num: 32
I (468) wifi: Init management short buffer num: 32
I (468) wifi: Init static rx buffer size: 1600
I (478) wifi: Init static rx buffer num: 10
I (478) wifi: Init dynamic rx buffer num: 32
[1B][0;32mI (578) phy: phy_version: 4102, 2fa7a43, Jul 15 2019, 13:06:06, 0, 0[1B][0m
I (578) wifi: mode : sta (30:ae:a4:13:6e:3c)
[1B][0;32mI (578) SmartSwitch_WiFi: Waiting for wifi[1B][0m
[1B][0;32mI (578) SmartSwitch_WiFi: STA STARTED[1B][0m
I (708) wifi: new:<1,1>, old:<1,0>, ap:<255,255>, sta:<1,1>, prof:1
I (1698) wifi: state: init -> auth (b0)
I (1698) wifi: state: auth -> assoc (0)
I (1708) wifi: state: assoc -> run (10)
I (1818) wifi: connected with ABfortune5, channel 1, 40U, bssid = 74:da:88:df:33:40
I (1828) wifi: pm start, type: 1
[1B][0;32mI (3398) event: sta ip: 192.168.0.108, mask: 255.255.255.0, gw: 192.168.0.1[1B][0m
[1B][0;32mI (3398) SmartSwitch_WiFi: STA Got IP[1B][0m
[1B][0;32mI (3398) GPIO: SmartSwitch_Net Local called[1B][0m
[1B][0;32mI (3408) MQTT_Task: MQTT Client STARTED[1B][0m
[1B][0;32mI (3408) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE[1B][0m
[1B][0;32mI (3418) MQTT_Task: Other event id:7[1B][0m
[1B][0;32mI (3458) MQTT_CLIENT: Sending MQTT CONNECT message, type: 1, id: 0000[1B][0m
[1B][0;32mI (3488) MQTT_Task: Case: MQTT_EVENT_CONNECTED[1B][0m
[1B][0;32mI (3488) GPIO: SmartSwitch_Net OK called[1B][0m
[1B][0;32mI (3488) Json: Update JSON…[1B][0m
Data Length = 234
JSON DATA={
“Switch Status”: {
“CurrOpMode”: 0,
“SwitchCount”: 0,
“MasterSW”: 0,
“SW1”: 0,
“SW2”: 0,
“SW3”: 0,
“FanCount”: 0,
“Fan1Ctl”: 0,
“Fan1Speed”: 0
can any one suggest the answer.
thank you.
