Hello.
I am using an ESP32 to drive some 64x32 panels.
// MatrixHardware_ESP32_V0.h
#define R1_PIN 25
#define G1_PIN 5
#define B1_PIN 26
#define R2_PIN 27
#define G2_PIN 23
#define B2_PIN 14
#define A_PIN 13
#define B_PIN 21
#define C_PIN 18
#define D_PIN 19
#define E_PIN 22
#define LAT_PIN 15
#define OE_PIN 4
#define CLK_PIN 2
#define GPIO_PWM0A_OUT GPIO_NUM_32
#define GPIO_SYNC0_IN GPIO_NUM_34
GPIO 22, 32 and 34 are not connected to the panel.
My panels work just fine without them. Have no idea how, I did not design the PCB adapter.
I’ve successfully used GPIO 32 and 34 as INPUTS for some buttons, but I can’t seem to make GPIO 22 work. I’ve tried using it inside my code but it is always set to LOW.
Since GPIO 22 is not connected to the panel, I assumed that the library uses it somehow.
// SmartMatrixMultiplexedRefreshEsp32_Impl.h
i2s_parallel_config_t cfg={
.gpio_bus={R1_PIN, G1_PIN, B1_PIN, R2_PIN, G2_PIN, B2_PIN, LAT_PIN, OE_PIN, A_PIN, B_PIN, C_PIN, D_PIN, E_PIN, -1, -1, -1},
.gpio_clk=CLK_PIN,
.clkspeed_hz=ESP32_I2S_CLOCK_SPEED, // formula used is 80000000L/(cfg->clkspeed_hz + 1), must result in >=2. Acceptable values 26.67MHz, 20MHz, 16MHz, 13.34MHz...
.bits=MATRIX_I2S_MODE,
.bufa=0,
.bufb=0,
desccount,
desccount,
dmadesc_a,
dmadesc_b
How can I tell the library not to use the E_PIN ?
Where in the panel definition should I point out that the panel does not uses the E_PIN ?
The quickest solution was to #define E_PIN 40 inside MatrixHardware_ESP32_V0.h.
But I don’t know how safe this is, because I’ve tried setting it as 45 and the ESP would just crash infinitely, so the library is trying to use the E_PIN for something.
