StePet
March 17, 2023, 9:39am
#1
It can be found here.
The FastLED code is here .
If anyone runs this on a SmartMatrix setup, I’d appreciate a link to the code changes that were required to get it up and running.
If needed I’m happy to support navigating my code, I know it pretty much inside out by now. Certainly line 14, 15 and 71 need to be changed.
Thank you very much!
I’ve been trying to get your code to work on both Teensy 3.2 & Teensy 4.1 but haven’t had any success yet. Very puzzelling indeed.
b707
March 21, 2023, 10:12am
#3
Isn’t this a ready-to-go sketch? Or does it require some modifications to run?
StePet
March 21, 2023, 10:55am
#4
It is ready to go with FastLED as LED driver. SmartMatrix is a different driver, so some changes need to be made.
Here in the comments on top I explained what certainly needs to be adapted.
It would be cool if someone with a SmartMatrix around could implement the SM specific changes and share it here. Every needed change I could think of I explained in the new code - it should be pretty simple to use SM functions now at these few driverspecific places.
