For a school project, I’m trying to make a rudimentary CLI OS run on a 192x128 matrix array driven by a Teensy 4.0. Unfortunately, I’ve hit a wall regarding USB keyboard support. After stripping down an example sketch to the bare minimum and confirming it worked, I added initialization code for SmartMatrix and an attempt at drawing keystrokes to the screen, but this has made the USB keyboard - or at least the OnPress callback function - stop working…
The hardware is in a lab on campus, so I haven’t had the chance to troubleshoot more. Anyone know what the problem could be? (Onboard peripheral conflict? Variable name conflict? Overwritten RAM? Interrupt preemption hell?)
Source code:
// MATRIX GLOBAL STUFF
#include "USBHost_t36.h"
#include "KeyboardUtils.h" // couple of functions irrelevant to the issue (hopefully)
#define TERM_CHAR_WIDTH 4
#define TERM_CHAR_HEIGHT 6
#define COLOR_DEPTH 24 // Color depth (bits-per-pixel) of gfx layers
const uint16_t kMatrixWidth = 192;
const uint16_t kMatrixHeight = 128;
const uint8_t kPanelType = SM_PANELTYPE_HUB75_64ROW_MOD32SCAN; // 64x64 "HUB75E" 5-address panels
// see docs for options: https://github.com/pixelmatix/SmartMatrix/wiki
const uint32_t kMatrixOptions = (SM_HUB75_OPTIONS_C_SHAPE_STACKING); // aka "serpentine" - flip alternate rows to save cable length
uint8_t matrixBrightness = 255;
uint16_t termCursorX = 0;
uint16_t termCursorY = 0;
rgb24 termBgColor = { 0, 0, 0 };
rgb24 termTextColor = { 0, 255, 0 };
#ifdef USE_ADAFRUIT_GFX_LAYERS
// there's not enough allocated memory to hold the long strings used by this sketch by default, this increases the memory, but it may not be large enough
SMARTMATRIX_ALLOCATE_GFX_MONO_LAYER(scrollingLayer, kMatrixWidth, kMatrixHeight, 6 * 1024, 1, COLOR_DEPTH, kScrollingLayerOptions);
#else
// KEYBOARD GLOBAL STUFF
USBHost myusb;
KeyboardController keyboard1(myusb);
// while not referenced anywhere, this is what actually does key decoding
USBHIDParser hid1(myusb);
// SDIO GLOBAL STUFF
// wait 5 sec for Arduino Serial Monitor
unsigned long start = millis();
while (!Serial)
if (millis() - start > 5000)
break;
Serial.println("\n\n### matrixOS Serial Console ###\n");
// MATRIX INIT STUFF
matrix.setBrightness(matrixBrightness);
backgroundLayer.enableColorCorrection(true); // probably good to have IDK
backgroundLayer.setFont(font3x5);
// KEYBOARD INIT STUFF
myusb.begin();
keyboard1.attachPress(OnPress);
// keyboard1.attachRawPress(OnRawPress);
// keyboard1.attachRawRelease(OnRawRelease);
// SDIO INIT STUFF
myusb.Task();
// Everything else should be a TeensyThread... eventually
// clear screen
// backgroundLayer.fillScreen(defaultBackgroundColor);
// backgroundLayer.swapBuffers();
// MATRIX FUNCTIONS
void advanceCursor(){
termCursorX += TERM_CHAR_WIDTH;
if (termCursorX > kMatrixWidth){
termCursorX = 0;
termCursorY += TERM_CHAR_HEIGHT;
// KEYBOARD FUNCTIONS
// TODO: as this is (presumably) an ISR, consider limiting what it does
void OnPress(int key) {
Serial.println("POLO");
unsigned char key_dec = decodeKey(key, keyboard1.getOemKey(), keyboard1.getModifiers(), keyboard1.LEDS());
if (key_dec) {
Serial.print((char)key_dec);
backgroundLayer.drawChar(termCursorX, termCursorY, termTextColor, (char)key_dec);
advanceCursor();
