I just did a test modifying the MultipleTextLayersGfx sketch and it can display black text over the FastLED pattern:
See scrollingLayer00.setColor({0,0,0});
This example shows how multiple scrolling text layers can be used
This example requires the Adafruit_GFX Library, which you can install through Arduino Library Manager
The "GFX" Layers in SmartMatrix Library 4.0 depend on Adafruit_GFX and give access to using large fonts included
with Adafruit_GFX, and the ability to add custom fonts
Performance of the "GFX" layers has been optimized, and with the Teensy 4, you can have 10 scrolling text layers
on a 128x64 panel, and still refresh the panel at 240Hz
Optionally draw a pattern behind the text layers using FastLED (same code as the FastLED_Functions example) by
removing the comments from `#define INCLUDE_FASTLED_BACKGROUND` below. With the Teensy 4 you'll still see
128x64 @ 240Hz Refresh even with the pattern updating at 60 FPS!
//#include <MatrixHardware_Teensy3_ShieldV4.h> // SmartLED Shield for Teensy 3 (V4)
//#include <MatrixHardware_Teensy3_ShieldV1toV3.h> // SmartMatrix Shield for Teensy 3 V1-V3
//#include <MatrixHardware_ESP32_V0.h> // This file contains multiple ESP32 hardware configurations, edit the file to define GPIOPINOUT (or add #define GPIOPINOUT with a hardcoded number before this #include)
//#include "MatrixHardware_Custom.h" // Copy an existing MatrixHardware file to your Sketch directory, rename, customize, and you can include it like this
#include <Fonts/Picopixel.h>
#include <Fonts/TomThumb.h>
#include <Fonts/FreeMono12pt7b.h>
#include <Fonts/FreeMonoBold18pt7b.h>
#include <Fonts/FreeMonoBoldOblique24pt7b.h>
#include <Fonts/FreeSerif24pt7b.h>
#include <Fonts/Org_01.h>
#include <Fonts/Tiny3x3a2pt7b.h>
#include <Fonts/FreeSerifItalic9pt7b.h>
#include <Fonts/FreeSansOblique24pt7b.h>
const uint16_t kMatrixWidth = 64; // Set to the width of your display, must be a multiple of 8
const uint16_t kMatrixHeight = 64; // Set to the height of your display
const uint8_t kPanelType = SM_PANELTYPE_HUB75_64ROW_MOD32SCAN; // Choose the configuration that matches your panels. See more details in MatrixCommonHub75.h and the docs: https://github.com/pixelmatix/SmartMatrix/wiki
#ifdef INCLUDE_FASTLED_BACKGROUND
// Using the backwards compatible ALLOCATION macro is fine for smaller fonts
SMARTMATRIX_ALLOCATE_SCROLLING_LAYER(scrollingLayer07, kMatrixWidth, kMatrixHeight, COLOR_DEPTH, kScrollingLayerOptions);
SMARTMATRIX_ALLOCATE_SCROLLING_LAYER(scrollingLayer08, kMatrixWidth, kMatrixHeight, COLOR_DEPTH, kScrollingLayerOptions);
SMARTMATRIX_ALLOCATE_SCROLLING_LAYER(scrollingLayer09, kMatrixWidth, kMatrixHeight, COLOR_DEPTH, kScrollingLayerOptions);
// For larger fonts, you need to allocate enough memory to hold the entire scrolling text bitmap (the bounds of all the characters in the string) in memory
// and this may be larger than kMatrixWidth*kMatrixHeight. Use the SMARTMATRIX_ALLOCATE_GFX_MONO_LAYER macro, which allows for setting the character bitmap
// to different size than the matrix bounds. We allocate several times the default amount of memory here:
SMARTMATRIX_ALLOCATE_GFX_MONO_LAYER(scrollingLayer00, kMatrixWidth, kMatrixHeight, kMatrixWidth*3, kMatrixHeight, COLOR_DEPTH, kScrollingLayerOptions);
// Basing the bitmap allocation on the matrix size doesn't make much sense, as the size of the scrolling text is mostly independent of matrix size
// Here we allocate an amount of memory that is known to work as a 6kb wide bitmap, with height of 1. The layer will resize the bitmap to fit the text
SMARTMATRIX_ALLOCATE_GFX_MONO_LAYER(scrollingLayer01, kMatrixWidth, kMatrixHeight, 6*1024, 1, COLOR_DEPTH, kScrollingLayerOptions);
// The required sizes for some of the layers are printed out to serial, so these layers can be sized exactly to the needed bitmap dimensions
SMARTMATRIX_ALLOCATE_GFX_MONO_LAYER(scrollingLayer02, kMatrixWidth, kMatrixHeight, 168, 48, COLOR_DEPTH, kScrollingLayerOptions);
SMARTMATRIX_ALLOCATE_GFX_MONO_LAYER(scrollingLayer03, kMatrixWidth, kMatrixHeight, 224, 40, COLOR_DEPTH, kScrollingLayerOptions);
// The same thing but in total pixels not width/height:
SMARTMATRIX_ALLOCATE_GFX_MONO_LAYER(scrollingLayer04, kMatrixWidth, kMatrixHeight, 8832, 1, COLOR_DEPTH, kScrollingLayerOptions);
// For small strings/fonts, there's actually a memory savings compared to the previous method of sizing the layer bitmap to the matrix size:
SMARTMATRIX_ALLOCATE_GFX_MONO_LAYER(scrollingLayer05, kMatrixWidth, kMatrixHeight, 256, 1, COLOR_DEPTH, kScrollingLayerOptions);
// This layer is sized too small, and you'll only see part of the text on the screen, also look for "Layer 06 text doesn't fit" printed to Serial
SMARTMATRIX_ALLOCATE_GFX_MONO_LAYER(scrollingLayer06, kMatrixWidth, kMatrixHeight, 128, 1, COLOR_DEPTH, kScrollingLayerOptions);
const int randomSpeedMax = 120;
const int randomSpeedMin = 20;
// select random offset, from range of what's visible on screen (0 - matrixHeight-layerHeight)
void chooseRandomVisibleOffset(SMLayerGFXMono<rgb24, rgb1, 0> *layer) {
// first get the total number of pixels on the screen in the text's vertical direction
int16_t maxHeight = (layer->getLayerRotation() % 2) ? kMatrixWidth : kMatrixHeight;
// subtract the height of the text
maxHeight -= layer->getLocalHeight();
// get random number within range 0..maxHeight
if(maxHeight > 0)
maxHeight = random(maxHeight);
else
maxHeight = 0;
// set offset that keeps the text visible
layer->setOffsetFromTop(maxHeight);
rgb24 chooseRandomBrightColor() {
rgb24 color;
switch(random(3)) {
case 0:
color = rgb24(random(0x80, 0x100), random(0x40), random(0x40));
break;
case 1:
color = rgb24(random(0x40), random(0x80, 0x100), random(0x40));
break;
case 2:
color = rgb24(random(0x40), random(0x40), random(0x80, 0x100));
default:
break;
return color;
void printDimensionsOfString(const char text[], const GFXfont *font) {
// we use scrollingLayer00 for this as it's a temporary test, and we'll set the actual font and text layer
uint16_t w, h;
scrollingLayer00.setFont(font);
scrollingLayer00.getDimensionsOfPrintedString(text, &w, &h);
Serial.print(w);
Serial.print("x");
Serial.print(h);
Serial.print(" (");
Serial.print(w*h);
Serial.print(" pixels, ");
Serial.print(w*h/8);
Serial.println(" bytes)");
#include <FastLED.h>
// The 32bit version of our coordinates
static uint16_t x;
static uint16_t y;
static uint16_t z;
// We're using the x/y dimensions to map to the x/y pixels on the matrix. We'll
// use the z-axis for "time". speed determines how fast time moves forward. Try
// 1 for a very slow moving effect, or 60 for something that ends up looking like
// water.
// uint16_t speed = 1; // almost looks like a painting, moves very slowly
uint16_t speed = 10; // a nice starting speed, mixes well with a scale of 100
// uint16_t speed = 33;
// uint16_t speed = 100; // wicked fast!
// Scale determines how far apart the pixels in our noise matrix are. Try
// changing these values around to see how it affects the motion of the display. The
// higher the value of scale, the more "zoomed out" the noise iwll be. A value
// of 1 will be so zoomed in, you'll mostly see solid colors.
// uint16_t scale = 1; // mostly just solid colors
// uint16_t scale = 4011; // very zoomed out and shimmery
uint16_t scale = 31;
// This is the array that we keep our computed noise values in
uint8_t noise[kMatrixWidth][kMatrixHeight];
// Fill the x/y array of 8-bit noise values using the inoise8 function.
void fillnoise8() {
for(int i = 0; i < kMatrixWidth; i++) {
int ioffset = scale * i;
for(int j = 0; j < kMatrixHeight; j++) {
int joffset = scale * j;
noise[i][j] = inoise8(x + ioffset,y + joffset,z);
z += speed;
Serial.begin(115200);
delay(2000);
randomSeed(analogRead(0));
// Initialize our coordinates to some random values
x = random16();
y = random16();
z = random16();
matrix.addLayer(&scrollingLayer00);
matrix.addLayer(&scrollingLayer01);
matrix.addLayer(&scrollingLayer02);
matrix.addLayer(&scrollingLayer03);
matrix.addLayer(&scrollingLayer04);
matrix.addLayer(&scrollingLayer05);
matrix.addLayer(&scrollingLayer06);
matrix.addLayer(&scrollingLayer07);
matrix.addLayer(&scrollingLayer08);
matrix.addLayer(&scrollingLayer09);
Serial.print("Bitmap size to hold `Layer 00` in font FreeMono12pt7b: ");
printDimensionsOfString("Layer 00", &FreeMono12pt7b);
Serial.print("Bitmap size to hold `Layer 01` in font FreeMonoBold18pt7b: ");
printDimensionsOfString("Layer 01", &FreeMonoBold18pt7b);
Serial.print("Bitmap size to hold `Layer 02` in font FreeSerif24pt7b: ");
printDimensionsOfString("Layer 02", &FreeSerif24pt7b);
Serial.print("Bitmap size to hold `Layer 03` in font FreeMonoBoldOblique24pt7b: ");
printDimensionsOfString("Layer 03", &FreeMonoBoldOblique24pt7b);
Serial.print("Bitmap size to hold `Layer 04` in font FreeSansOblique24pt7b: ");
printDimensionsOfString("Layer 04", &FreeSansOblique24pt7b);
Serial.print("Bitmap size to hold `Layer 05` in font Picopixel: ");
printDimensionsOfString("Layer 05", &Picopixel);
Serial.print("Bitmap size to hold `Layer 06` in font FreeSerifItalic9pt7b: ");
printDimensionsOfString("Layer 06", &FreeSerifItalic9pt7b);
scrollingLayer00.setMode((ScrollMode)random(3));
scrollingLayer01.setMode((ScrollMode)random(3));
scrollingLayer02.setMode((ScrollMode)random(3));
scrollingLayer03.setMode((ScrollMode)random(3));
scrollingLayer04.setMode((ScrollMode)random(3));
scrollingLayer05.setMode((ScrollMode)random(3));
scrollingLayer06.setMode((ScrollMode)random(3));
scrollingLayer07.setMode((ScrollMode)random(3));
scrollingLayer08.setMode((ScrollMode)random(3));
scrollingLayer09.setMode((ScrollMode)random(3));
scrollingLayer01.setColor(chooseRandomBrightColor());
scrollingLayer02.setColor(chooseRandomBrightColor());
scrollingLayer03.setColor(chooseRandomBrightColor());
scrollingLayer04.setColor(chooseRandomBrightColor());
scrollingLayer05.setColor(chooseRandomBrightColor());
scrollingLayer06.setColor(chooseRandomBrightColor());
scrollingLayer07.setColor(chooseRandomBrightColor());
scrollingLayer08.setColor(chooseRandomBrightColor());
scrollingLayer09.setColor(chooseRandomBrightColor());
scrollingLayer00.setSpeed(random(randomSpeedMax-randomSpeedMin) + randomSpeedMin);
scrollingLayer01.setSpeed(random(randomSpeedMax-randomSpeedMin) + randomSpeedMin);
scrollingLayer02.setSpeed(random(randomSpeedMax-randomSpeedMin) + randomSpeedMin);
scrollingLayer03.setSpeed(random(randomSpeedMax-randomSpeedMin) + randomSpeedMin);
scrollingLayer04.setSpeed(random(randomSpeedMax-randomSpeedMin) + randomSpeedMin);
scrollingLayer05.setSpeed(random(randomSpeedMax-randomSpeedMin) + randomSpeedMin);
scrollingLayer06.setSpeed(random(randomSpeedMax-randomSpeedMin) + randomSpeedMin);
scrollingLayer07.setSpeed(random(randomSpeedMax-randomSpeedMin) + randomSpeedMin);
scrollingLayer08.setSpeed(random(randomSpeedMax-randomSpeedMin) + randomSpeedMin);
scrollingLayer09.setSpeed(random(randomSpeedMax-randomSpeedMin) + randomSpeedMin);
scrollingLayer00.setFont(&FreeMono12pt7b);
scrollingLayer01.setFont(&FreeMonoBold18pt7b);
scrollingLayer02.setFont(&FreeSerif24pt7b);
scrollingLayer03.setFont(&FreeMonoBoldOblique24pt7b);
scrollingLayer04.setFont(&FreeSansOblique24pt7b);
scrollingLayer05.setFont(&Picopixel);
scrollingLayer06.setFont(&FreeSerifItalic9pt7b);
scrollingLayer07.setFont(&TomThumb);
scrollingLayer08.setFont(&Tiny3x3a2pt7b);
scrollingLayer09.setFont(&Org_01);
scrollingLayer00.setRotation(random(4));
scrollingLayer01.setRotation(random(4));
scrollingLayer02.setRotation(random(4));
scrollingLayer03.setRotation(random(4));
scrollingLayer04.setRotation(random(4));
scrollingLayer05.setRotation(random(4));
scrollingLayer06.setRotation(random(4));
scrollingLayer07.setRotation(random(4));
scrollingLayer08.setRotation(random(4));
scrollingLayer09.setRotation(random(4));
if(scrollingLayer00.start("Layer 00", -1) < 0)
Serial.println("Layer 00 text doesn't fit");
if(scrollingLayer01.start("Layer 01", -1) < 0)
Serial.println("Layer 01 text doesn't fit");
if(scrollingLayer02.start("Layer 02", -1) < 0)
Serial.println("Layer 02 text doesn't fit");
if(scrollingLayer03.start("Layer 03", -1) < 0)
Serial.println("Layer 03 text doesn't fit");
if(scrollingLayer04.start("Layer 04", -1) < 0)
Serial.println("Layer 04 text doesn't fit");
if(scrollingLayer05.start("Layer 05", -1) < 0)
Serial.println("Layer 05 text doesn't fit");
if(scrollingLayer06.start("Layer 06", -1) < 0)
Serial.println("Layer 06 text doesn't fit");
if(scrollingLayer07.start("Layer 07", -1) < 0)
Serial.println("Layer 07 text doesn't fit");
if(scrollingLayer08.start("Layer 08", -1) < 0)
Serial.println("Layer 08 text doesn't fit");
if(scrollingLayer09.start("Layer 09", -1) < 0)
Serial.println("Layer 09 text doesn't fit");
chooseRandomVisibleOffset(&scrollingLayer00);
chooseRandomVisibleOffset(&scrollingLayer01);
chooseRandomVisibleOffset(&scrollingLayer02);
chooseRandomVisibleOffset(&scrollingLayer03);
chooseRandomVisibleOffset(&scrollingLayer04);
chooseRandomVisibleOffset(&scrollingLayer05);
chooseRandomVisibleOffset(&scrollingLayer06);
chooseRandomVisibleOffset(&scrollingLayer07);
chooseRandomVisibleOffset(&scrollingLayer08);
chooseRandomVisibleOffset(&scrollingLayer09);
static uint8_t circlex = 0;
static uint8_t circley = 0;
// if sketch uses swapBuffers(false), wait to get a new backBuffer() pointer after the swap is done:
while(backgroundLayer.isSwapPending());
rgb24 *buffer = backgroundLayer.backBuffer();
static uint8_t ihue=0;
fillnoise8();
// We use the value at the (i,j) coordinate in the noise
// array for our brightness, and the flipped value from (j,i)
// for our pixel's hue.
buffer[kMatrixWidth*j + i] = CRGB(CHSV(noise[j][i],255,noise[i][j]));
// You can also explore other ways to constrain the hue used, like below
// buffer[kMatrixHeight*j + i] = CRGB(CHSV(ihue + (noise[j][i]>>2),255,noise[i][j]));
ihue+=1;
backgroundLayer.fillCircle(circlex % kMatrixWidth, circley % kMatrixHeight, 6, (rgb24)CRGB(CHSV(ihue+128,255,255)));
circlex += random16(2);
circley += random16(2);
// buffer is filled completely each time, use swapBuffers without buffer copy to save CPU cycles
matrix.countFPS(); // print the loop() frames per second to Serial
EVERY_N_SECONDS( 1 ) {
Serial.print("Refresh Rate: ");
Serial.println(matrix.getRefreshRate());
#else
delay(1000);
