just a quick question. Is hub75e for 64x64 matrix displays supported by the library and the shield(SmartLED Shield for Teensy 4)? I found some flags in the source code
relating to hub75e and FM6126A which suggest it is supported.
Yes, SmartLED Shield for Teensy 4 drives five address pins and 64x64 panels (with compatible chipsets) are supported.
I rarely receive panels that look like the pictures in Aliexpress. They usually just ship what’s on hand. FM6126A is supported on Teensy.
(That old discussion was talking about adding HUB75E support to a bare Teensy 3, which still only supports 4 address lines in the official SmartMatrix Library. SmartLED Shield for Teensy 3/4 support 5 address lines)
just wanted to let you know that i got some 64x64 HUB75E P2 panels from Alibaba (Chip FM6124)
and two smartmatrix shields.
FeatureDemo works nicely with
