Hi there,
I use a HUB75E P3 64x64 LED panel with ESP32 / raspberry pi etc. I notice that each LED shows a tiny red dot if it is set to white and a tiny blue dot on the bottom when it shows magenta color.
I know and understand the concept that the color white is a combination of RGB. The LED shows white but it seems that the red component is brighter(?) than the others.
Since this is the only panel I have and I can not compare it to others, I have the question: If you are like 2 meters away from the panel, do you still see “the RGB components” of the color white or is it pure white?
Thanks guys,
Martin
