Hi all – thanks in advance.
Q: Is there a maximum number of pixels on a side, that the Teensy 4.1 and SmartMatrix can handle? Not asking about total resolution. The problem I’m having is with the arrangement of an array of 64x32 P4 panels.
My goal is to have a single column stack, with 9 - 64x32 horizontal panels forming a single array/screen.
I’m running an tweaked “Game of Life” code on it as part of an art project. The errors could also be my code – my skills are minimal and I’m learning as I go. I’m in the design phase exploring the tech and code. The physical parameters/panel layout are still fluid.
If I write my code (see below) so that I have 10 - 64x32 panels, stacked 1 across, 10 down, my code doesn’t work (a resolution of 64 x 320 = 20,480 pixels).
const uint8_t kMatrixWidth = 64; // 1 panel across
const uint8_t kMatrixHeight = 320; // 10 panels down
If I write my code so that I have 10 - 64x32 panels, stacked 2 across, 5 down, my code works (a resolution of 128 x 160 = 20,480 pixels).
const uint8_t kMatrixWidth = 128; // 2 panels across
const uint8_t kMatrixHeight = 160; // 5 panels down
Also, FWIW, if I do 7 panels in a vertical stack, it works (a resolution of 64 x 224 = 14,336 pixels)
const uint8_t kMatrixWidth = 64; // 1 panels across
const uint8_t kMatrixHeight = 224; // 7 panels down
“Doesn’t work” means the screens stop acting like an array and start mirroring the first screen, the colors are off, and the pixel positions are shifted – stair stepped.
The panels are well supplied with power. The array is connected in a long chain, simply going from Data Out to Data In.
TECH:
Panels: Hub75 P4 64x32 Mod16scan
Teensy 4.1
SmartMatrix Shield 4
5V/40 Amp power supply
CODE
I can post the whole code if that helps, but here’s the relevant chunk for the SmartMatrix
#include <MatrixHardware_Teensy4_ShieldV5.h> // Include the hardware configuration for SmartLED Shield (V5)
#include <FastLED.h>
and
#define COLOR_DEPTH 24 // This sketch and FastLED uses type `rgb24` directly, COLOR_DEPTH must be 24
const uint8_t kRefreshDepth = 48; // known working: 24, 36, 48
const uint8_t kPanelType = SMARTMATRIX_HUB75_32ROW_MOD16SCAN; // Assuming 32-row hub75 panels with mod16 scan
#define NUM_LEDS (kMatrixWidth * kMatrixHeight)
-andy
