Here is my code:
A red background with a “BLINK” message on it (it works)
and a blinked LED strip with all 144 LEDs. (but error : only 5 LEDs blinks…)
* Test with 64x32 Matrix and 144 led Strip
#include <SmartMatrix3.h>
#include <FastLED.h>
//Smartmatrix Const
const uint8_t kRefreshDepth = 24; // known working: 24, 36, 48
const uint8_t kDmaBufferRows = 2; // known working: 2-4, use 2 to save memory, more to keep from dropping frames and automatically lowering refresh rate
//LED Strip : pin 13 (CLK), 5v, Gnd with Smartmatrix shield
#define NUM_LEDS 144
#define DATA_PIN 13
CRGB leds[NUM_LEDS];
const int defaultBrightness = 100*(255/100); // full brightness
const rgb24 defaultBackgroundColor = {0x00, 0x00, 0x00};
const rgb24 redColor = {0xff, 0, 0};
const rgb24 whiteColor = {0xff, 0xff, 0xff};
//Strip LED
FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
//Matrix init
scrollingLayer.setOffsetFromTop(defaultScrollOffset);
//Display BLINK with red Background
backgroundLayer.setFont(font8x13);
backgroundLayer.fillScreen({0xc8, 0, 0});
backgroundLayer.drawString(12, 10, {0xff, 0xff, 0xff}, "BLINK");
// Switch on all 144 LEDs
for(int dot = 0; dot < NUM_LEDS; dot++) {
leds[dot] = CRGB::Red;
FastLED.show();
delay(1000);
leds[dot] = CRGB::Black;
FastLED.show();
delay(1000);
