I’m trying to go through the wiki and the example sketches but I’m a little new to programming and have some questions about drawing bitmaps, their placement etc.
What I don’t understand is from this chunk of code from the Bitmaps example:
// to use drawBitmap, must cast the pointer to pixelmatixlogo as (const gimp32x32bitmap*)
drawBitmap(x,y,(const gimp32x32bitmap*)&pixelmatixlogo);
I was able to get my 3 logos in the spots I wanted by tweaking the example to this:
// to use drawBitmap, must cast the pointer to gimp32x32bitmap as (const gimp32x32bitmap*)
drawBitmap(0,0,(const gimp32x32bitmap*)&oneBitmap);
drawBitmap(0,23,(const gimp32x32bitmap*)&twoBitmap);
drawBitmap(0,46,(const gimp32x32bitmap*)&threeBitmap);
Why is gimp32x32bitmap being referenced in the sketch? What does the commented text mean? These will be 3 static bitmaps that won’t require redrawing and I plan on adding some updating text that changes colours, is backgroundLayer.fillScreen needed?
