Thank you for writing back with your suggestions. They didn’t work, as I expected and have always experienced. Anyone, please point me to a WORKING 32x32 SmartMatrix with SD card that actually works. Did fresh install and managed all .h files requred and switched #define SD_CS 15 all to no avail.
Here is the error messages:
Arduino: 1.8.16 (Mac OS X), Board: "Arduino Yún"
In file included from /Volumes/EXTERNAL HD/Arduino/Sketchbook/Teensy32x32MatrixSlideshow-main/Slideshow/Slideshow.ino:7:0:
/Users/alfredolivas/Documents/Arduino/libraries/SmartMatrix/src/MatrixHardware_Teensy3_ShieldV1toV3.h:29:17: note: #pragma message: MatrixHardware: SmartMatrix Shield for Teensy 3 V1-V3
#pragma message "MatrixHardware: SmartMatrix Shield for Teensy 3 V1-V3"
In file included from /Volumes/EXTERNAL HD/Arduino/Sketchbook/Teensy32x32MatrixSlideshow-main/Slideshow/Slideshow.ino:9:0:
/Users/alfredolivas/Documents/Arduino/libraries/SmartMatrix/src/SmartMatrix.h:40:21: note: #pragma message: SmartMatrix Library version 4.000.003
# pragma message "SmartMatrix Library version 4.000.003"
Slideshow:22:29: error: expected constructor, destructor, or type conversion before '(' token
Slideshow:23:38: error: expected constructor, destructor, or type conversion before '(' token
Slideshow:24:37: error: expected constructor, destructor, or type conversion before '(' token
Slideshow:25:35: error: expected constructor, destructor, or type conversion before '(' token
/Volumes/EXTERNAL HD/Arduino/Sketchbook/Teensy32x32MatrixSlideshow-main/Slideshow/Slideshow.ino: In function 'void setup()':
Slideshow:58:3: error: 'matrix' was not declared in this scope
/Volumes/EXTERNAL HD/Arduino/Sketchbook/Teensy32x32MatrixSlideshow-main/Slideshow/Slideshow.ino:58:3: note: suggested alternative: 'atoi'
atoi
Slideshow:58:20: error: 'backgroundLayer' was not declared in this scope
/Volumes/EXTERNAL HD/Arduino/Sketchbook/Teensy32x32MatrixSlideshow-main/Slideshow/Slideshow.ino:58:20: note: suggested alternative: 'kBackgroundLayerOptions'
Slideshow:59:20: error: 'scrollingLayer' was not declared in this scope
Slideshow:60:20: error: 'indexedLayer' was not declared in this scope
Slideshow:67:29: error: 'cc24' was not declared in this scope
matrix.setColorCorrection(cc24);
/Volumes/EXTERNAL HD/Arduino/Sketchbook/Teensy32x32MatrixSlideshow-main/Slideshow/Slideshow.ino:67:29: note: suggested alternative: '._24'
._24
/Volumes/EXTERNAL HD/Arduino/Sketchbook/Teensy32x32MatrixSlideshow-main/Slideshow/Slideshow.ino: In function 'void loop()':
Slideshow:90:14: error: 'FatFile* FatVolume::vwd()' is private within this context
sd.vwd()->seekSet(pos);
In file included from /Users/alfredolivas/Documents/Arduino/libraries/SdFat/src/FatLib/FatLib.h:27:0,
from /Users/alfredolivas/Documents/Arduino/libraries/SdFat/src/SdFat.h:34,
from /Volumes/EXTERNAL HD/Arduino/Sketchbook/Teensy32x32MatrixSlideshow-main/Slideshow/Slideshow.ino:3:
/Users/alfredolivas/Documents/Arduino/libraries/SdFat/src/FatLib/FatVolume.h:336:12: note: declared private here
FatFile* vwd() {return &m_vwd;}
Slideshow:91:32: error: 'FatFile* FatVolume::vwd()' is private within this context
if(!file.openNext(sd.vwd(), O_READ)) {
Slideshow:95:20: error: 'FatFile* FatVolume::vwd()' is private within this context
pos = sd.vwd()->curPosition();
Slideshow:97:12: error: 'class SdFile' has no member named 'getFilename'; did you mean 'getName'?
file.getFilename(name);
getName
/Volumes/EXTERNAL HD/Arduino/Sketchbook/Teensy32x32MatrixSlideshow-main/Slideshow/Slideshow.ino: In function 'uint32_t bmpDraw(char*, uint8_t, uint8_t)':
Slideshow:200:12: error: 'matrix' was not declared in this scope
if((x >= matrix.getScreenWidth()) || (y >= matrix.getScreenHeight())) return 0;
/Volumes/EXTERNAL HD/Arduino/Sketchbook/Teensy32x32MatrixSlideshow-main/Slideshow/Slideshow.ino:200:12: note: suggested alternative: 'atoi'
atoi
Slideshow:249:23: error: 'matrix' was not declared in this scope
if((x+w-1) >= matrix.getScreenWidth()) w = matrix.getScreenWidth() - x;
/Volumes/EXTERNAL HD/Arduino/Sketchbook/Teensy32x32MatrixSlideshow-main/Slideshow/Slideshow.ino:249:23: note: suggested alternative: 'atoi'
atoi
Slideshow:250:23: error: 'matrix' was not declared in this scope
if((y+h-1) >= matrix.getScreenHeight()) h = matrix.getScreenWidth() - y;
/Volumes/EXTERNAL HD/Arduino/Sketchbook/Teensy32x32MatrixSlideshow-main/Slideshow/Slideshow.ino:250:23: note: suggested alternative: 'atoi'
atoi
Slideshow:279:13: error: 'matrix' was not declared in this scope
matrix.drawPixel(x+col, y+row, color);
/Volumes/EXTERNAL HD/Arduino/Sketchbook/Teensy32x32MatrixSlideshow-main/Slideshow/Slideshow.ino:279:13: note: suggested alternative: 'atoi'
atoi
Slideshow:283:9: error: 'matrix' was not declared in this scope
matrix.swapBuffers(true);
/Volumes/EXTERNAL HD/Arduino/Sketchbook/Teensy32x32MatrixSlideshow-main/Slideshow/Slideshow.ino:283:9: note: suggested alternative: 'atoi'
atoi
Multiple libraries were found for "SdFat.h"
Used: /Users/alfredolivas/Documents/Arduino/libraries/SdFat
Not used: /Users/alfredolivas/Documents/Arduino/libraries/SdFat_-_Adafruit_Fork
exit status 1
"Show verbose output during compilation"
option enabled in File -> Preferences.
