Hi all,
I’m using Teensy4.1 Board and SmartMatrix v4 (Old Version for Teensy3x).
Currently, I have a problem about stacking 2 panel 32x32 to 1 panel 64x32.
It’s not correct.
Below is my example (follow AnimatedGifs Example) and Image Gif.
#if (USE_SMARTMATRIX == 1)
/* SmartMatrix configuration and memory allocation */
#define COLOR_DEPTH 24 // Choose the color depth used for storing pixels in the layers: 24 or 48 (24 is good for most sketches - If the sketch uses type rgb24 directly, COLOR_DEPTH must be 24)
const uint16_t kMatrixWidth = 64; // Set to the width of your display, must be a multiple of 8
const uint16_t kMatrixHeight = 32; // Set to the height of your display
const uint8_t kDmaBufferRows = 4; // known working: 2-4, use 2 to save RAM, more to keep from dropping frames and automatically lowering refresh rate. (This isn’t used on ESP32, leave as default)
const uint8_t kPanelType = SM_PANELTYPE_HUB75_32ROW_MOD16SCAN; // Choose the configuration that matches your panels. See more details in MatrixCommonHub75.h and the docs: Home · pixelmatix/SmartMatrix Wiki · GitHub
const uint32_t kMatrixOptions = (SM_HUB75_OPTIONS_NONE); // see docs for options: Home · pixelmatix/SmartMatrix Wiki · GitHub
Gif File:
Any help trouble shooting would be much appreciated!
Thank you!
