the library is great, but I found no answer to my question.
The example “AnimatedGifs” works great with 32x32 pixel gifs. I have two 64x64 panels.
Can i specify, where the gif should be played on the display? By default, the gif is always played in the top left corner.
Looking at the AnimatedGIFs example, It looks like you can modify drawPixelCallback to add offsets to x and y. You could use global variables for the offsets if you wanted to change the position dynamically. Haven’t tried it but it should work…
