Greets all. I am looking for support with a sketch i am using for Teensy4 and smartmatrix with 64 X 32 hub75 panel. I understand that the sketch has been modified. I am trying to connect the Teensy4 to either a PC or Raspberry Pi4. The application I am using is Mission Pinball Framework. I have followed the MPF instructions and have had example sketches running on the Teensy. I believe the sketch was written for an older version of smartmatrix. Any assistance is appreciated
SmartMatrix Pinball DMD code for Teensy, based on:
SmartMatrix Features Demo - Louis Beaudoin (Pixelmatix)
This example code is released into the public domain
//#include <SmartLEDShieldV4.h> // this line must be first if using a V4 shield
#include <MatrixHardware_Teensy4_ShieldV5.h>
#include <usb_serial.h>
const uint8_t kRefreshDepth = 24; // known working: 24, 36, 48
const int defaultBrightness = 100*(255/100); // full brightness
//const int defaultBrightness = 15*(255/100); // dim: 15% brightness
const rgb24 defaultBackgroundColor = {0, 0, 0};
// Teensy 3.0 has the LED on pin 13
const int ledPin = 13;
boolean frameOn = false;
int dataPos = 0;
int dataExpected = 0;
bool gotCommand = false;
int commandPos = 0;
const int USB_MARKER_LENGTH = 4;
const int USB_COMMAND_LENGTH = 8;
const uint8_t usbMarker[USB_MARKER_LENGTH] = {0xBA, 0x11, 0x00, 0x03};
uint8_t usbCommand[USB_COMMAND_LENGTH];
// the setup() method runs once, when the sketch starts
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
Serial.begin(2500000); // according to the Teensy docs this doesn't actually matter, will use USB speed
//matrix.addLayer(&scrollingLayer);
// matrix.addLayer(&indexedLayer);
// backgroundLayer.setBrightness
// clear screen
// the loop() method runs over and over again,
// as long as the board has power
uint16_t frameCount = 0;
char* buffer = (char*)backgroundLayer.backBuffer();
int bytesAvail = Serial.available();
boolean swap = false;
if ((bytesAvail > 1) && (dataPos > 0))
if (bytesAvail > dataExpected) bytesAvail = dataExpected;
int count = Serial.readBytes(&buffer[dataPos], bytesAvail);
dataPos += count;
dataExpected -= count;
if (dataExpected == 0) {
swap = true;
else if (bytesAvail) {
char val = Serial.read();
if (gotCommand)
buffer[dataPos++] = val;
dataExpected--;
swap = true;
else if (commandPos < USB_MARKER_LENGTH) {
usbCommand[commandPos] = val;
if (usbCommand[commandPos] == usbMarker[commandPos]) {
commandPos++;
else {
commandPos = 0;
else if (commandPos < USB_COMMAND_LENGTH) {
commandPos++;
if (commandPos >= USB_COMMAND_LENGTH)
gotCommand = true;
backgroundLayer.swapBuffers(true);
dataPos=0;
dataExpected = kMatrixWidth * kMatrixHeight * 3;
if (swap) {
frameCount++;
gotCommand = false;
commandPos = 0;
char frameText[12];
itoa(frameCount, frameText, 10);
dataPos = 0;
digitalWrite(ledPin, frameOn);
frameOn = !frameOn;
