Smartmatrix warnings with Teensy 1.58 beta 3
I was building some examples on a Teensy 4.1, and the new compiler used in the 1.58 beta versions throws some new warnings. It appears to work with the warnings, but it would be nice to get the code cleaned up. If I use the compiler in the 1.57 release, it works find.
Here are the warnings:
In file included from /home/meissner/Arduino/libraries/SmartMatrix/src/Layer_BackgroundGfx.h:173,
                 from /home/meissner/Arduino/libraries/SmartMatrix/src/SmartMatrix.h:59,
                 from /home/meissner/Arduino/Tests/RGB_Matrix/Adafruit_Gfx/Adafruit_Gfx.ino:39:
/home/meissner/Arduino/libraries/SmartMatrix/src/Layer_BackgroundGfx_Impl.h: In instantiation of 'void SMLayerBackgroundGFX<RGB, optionFlags>::swapBuffers(bool) [with RGB = rgb24; unsigned int optionFlags = 0]':
/home/meissner/Arduino/Tests/RGB_Matrix/Adafruit_Gfx/Adafruit_Gfx.ino:142:55:   required from here
/home/meissner/Arduino/libraries/SmartMatrix/src/Layer_BackgroundGfx_Impl.h:197:19: warning: 'void* memcpy(void*, const void*, size_t)' writing to an object of type 'struct rgb24' with no trivial copy-assignment; use copy-assignment or copy-initialization instead [-Wclass-memaccess]
  197 |             memcpy(backgroundBuffers[1], backgroundBuffers[0], sizeof(RGB) * (this->matrixWidth * this->matrixHeight));
In file included from /home/meissner/Arduino/libraries/SmartMatrix/src/SmartMatrix.h:50,
/home/meissner/Arduino/libraries/SmartMatrix/src/MatrixCommon.h:139:16: note: 'struct rgb24' declared here
  139 | typedef struct rgb24 {
/home/meissner/Arduino/libraries/SmartMatrix/src/Layer_BackgroundGfx_Impl.h:199:19: warning: 'void* memcpy(void*, const void*, size_t)' writing to an object of type 'struct rgb24' with no trivial copy-assignment; use copy-assignment or copy-initialization instead [-Wclass-memaccess]
  199 |             memcpy(backgroundBuffers[0], backgroundBuffers[1], sizeof(RGB) * (this->matrixWidth * this->matrixHeight));
In file included from /home/meissner/Arduino/libraries/SmartMatrix/src/SmartMatrix.h:218,
/home/meissner/Arduino/libraries/SmartMatrix/src/MatrixTeensy4Hub75Refresh_Impl.h: In instantiation of 'static void SmartMatrixRefreshT4<refreshDepth, matrixWidth, matrixHeight, panelType, optionFlags>::hardwareSetup() [with int refreshDepth = 36; int matrixWidth = 64; int matrixHeight = 64; unsigned char panelType = 2; long unsigned int optionFlags = 0]':
/home/meissner/Arduino/libraries/SmartMatrix/src/MatrixTeensy4Hub75Refresh_Impl.h:389:18:   required from 'static void SmartMatrixRefreshT4<refreshDepth, matrixWidth, matrixHeight, panelType, optionFlags>::begin() [with int refreshDepth = 36; int matrixWidth = 64; int matrixHeight = 64; unsigned char panelType = 2; long unsigned int optionFlags = 0]'
/home/meissner/Arduino/libraries/SmartMatrix/src/MatrixTeensy4Hub75Calc_Impl.h:272:97:   required from 'void SmartMatrixHub75Calc<refreshDepth, matrixWidth, matrixHeight, panelType, optionFlags>::begin() [with int refreshDepth = 36; int matrixWidth = 64; int matrixHeight = 64; unsigned char panelType = 2; long unsigned int optionFlags = 0]'
/home/meissner/Arduino/Tests/RGB_Matrix/Adafruit_Gfx/Adafruit_Gfx.ino:380:15:   required from here
/home/meissner/Arduino/libraries/SmartMatrix/src/MatrixTeensy4Hub75Refresh_Impl.h:669:88: warning: taking address of packed member of 'SmartMatrixRefreshT4<36, 64, 64, 2, 0>::timerpair' may result in an unaligned pointer value [-Waddress-of-packed-member]
  669 |     sourceAddress = (volatile uint32_t*) & (matrixUpdateRows[0].rowbits[0].timerValues.timer_oe);
In file included from /home/meissner/Arduino/libraries/SmartMatrix/src/SmartMatrix.h:219,
/home/meissner/Arduino/libraries/SmartMatrix/src/MatrixTeensy4Hub75Calc_Impl.h: In instantiation of 'static void SmartMatrixHub75Calc<refreshDepth, matrixWidth, matrixHeight, panelType, optionFlags>::loadMatrixBuffers48(volatile rowDataStruct*, unsigned int) [with int refreshDepth = 36; int matrixWidth = 64; int matrixHeight = 64; unsigned char panelType = 2; long unsigned int optionFlags = 0; SmartMatrixHub75Calc<refreshDepth, matrixWidth, matrixHeight, panelType, optionFlags>::rowDataStruct = SmartMatrixRefreshT4<36, 64, 64, 2, 0>::rowDataStruct]':
/home/meissner/Arduino/libraries/SmartMatrix/src/MatrixTeensy4Hub75Calc_Impl.h:548:24:   required from 'static void SmartMatrixHub75Calc<refreshDepth, matrixWidth, matrixHeight, panelType, optionFlags>::loadMatrixBuffers(unsigned int) [with int refreshDepth = 36; int matrixWidth = 64; int matrixHeight = 64; unsigned char panelType = 2; long unsigned int optionFlags = 0]'
/home/meissner/Arduino/libraries/SmartMatrix/src/MatrixTeensy4Hub75Calc_Impl.h:168:113:   required from 'static void SmartMatrixHub75Calc<refreshDepth, matrixWidth, matrixHeight, panelType, optionFlags>::matrixCalculations(bool) [with int refreshDepth = 36; int matrixWidth = 64; int matrixHeight = 64; unsigned char panelType = 2; long unsigned int optionFlags = 0]'
/home/meissner/Arduino/libraries/SmartMatrix/src/MatrixTeensy4Hub75Calc_Impl.h:270:121:   required from 'void SmartMatrixHub75Calc<refreshDepth, matrixWidth, matrixHeight, panelType, optionFlags>::begin() [with int refreshDepth = 36; int matrixWidth = 64; int matrixHeight = 64; unsigned char panelType = 2; long unsigned int optionFlags = 0]'
/home/meissner/Arduino/libraries/SmartMatrix/src/MatrixTeensy4Hub75Calc_Impl.h:384:15: warning: 'void* memset(void*, int, size_t)' clearing an object of non-trivial type 'rgb48' {aka 'struct rgb48'}; use assignment or value-initialization instead [-Wclass-memaccess]
  384 |         memset(tempRow0, 0, sizeof(tempRow0));
/home/meissner/Arduino/libraries/SmartMatrix/src/MatrixCommon.h:159:16: note: 'rgb48' {aka 'struct rgb48'} declared here
  159 | typedef struct rgb48 {
/home/meissner/Arduino/libraries/SmartMatrix/src/MatrixTeensy4Hub75Calc_Impl.h:385:15: warning: 'void* memset(void*, int, size_t)' clearing an object of non-trivial type 'rgb48' {aka 'struct rgb48'}; use assignment or value-initialization instead [-Wclass-memaccess]
  385 |         memset(tempRow1, 0, sizeof(tempRow1));
Memory Usage on Teensy 4.1:
  FLASH: code:53692, data:9864, headers:9144   free for files:8053764
   RAM1: variables:37856, code:51048, padding:14488   free for local variables:420896
   RAM2: variables:19680  free for malloc/new:504608
Here is the code that I used:
 * This example shows how to use the Adafruit_GFX compatible Layers in SmartMatrix Library
 * This example was adapted from Adafruit's FX example for the Adafruit ILI9341 Breakout and Shield, see text below
  This is our GFX example for the Adafruit ILI9341 Breakout and Shield
  ----> http://www.adafruit.com/products/1651
  Check out the links above for our tutorials and wiring diagrams
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface (RST is optional)
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
//#include <MatrixHardware_Teensy3_ShieldV4.h>        // SmartLED Shield for Teensy 3 (V4)
//#include <MatrixHardware_Teensy4_ShieldV5.h>        // SmartLED Shield for Teensy 4 (V5)
//#include <MatrixHardware_Teensy3_ShieldV1toV3.h>    // SmartMatrix Shield for Teensy 3 V1-V3
//#include <MatrixHardware_ESP32_V0.h>                // This file contains multiple ESP32 hardware configurations, edit the file to define GPIOPINOUT (or add #define GPIOPINOUT with a hardcoded number before this #include)
//#include "MatrixHardware_Custom.h"                  // Copy an existing MatrixHardware file to your Sketch directory, rename, customize, and you can include it like this
#if defined(ARDUINO_TEENSY40) || defined(ARDUINO_TEENSY41)
#elif defined(ARDUINO_TEENSY35) || defined(ARDUINO_TEENSY36)
#include <MatrixHardware_Teensy4_ShieldV4.h>		// SmartLED Shield for Teensy 4 (V5)
#else
#error "Include the correct header for the microprocessor"
#define COLOR_DEPTH 24                  // Choose the color depth used for storing pixels in the layers: 24 or 48 (24 is good for most sketches - If the sketch uses type `rgb24` directly, COLOR_DEPTH must be 24)
#define kMatrixWidth 64                 // Set to the width of your display, must be a multiple of 8
#define kMatrixHeight 64                // Set to the height of your display
const uint8_t kRefreshDepth = 36;       // Tradeoff of color quality vs refresh rate, max brightness, and RAM usage.  36 is typically good, drop down to 24 if you need to.  On Teensy, multiples of 3, up to 48: 3, 6, 9, 12, 15, 18, 21, 24, 27, 30, 33, 36, 39, 42, 45, 48.  On ESP32: 24, 36, 48
const uint8_t kDmaBufferRows = 4;       // known working: 2-4, use 2 to save RAM, more to keep from dropping frames and automatically lowering refresh rate.  (This isn't used on ESP32, leave as default)
// Choose the configuration that matches your panels.  See more details in
// MatrixCommonHub75.h and the docs: https://github.com/pixelmatix/SmartMatrix/wiki
#if kMatrixHeight == 64
const uint8_t kPanelType = SM_PANELTYPE_HUB75_64ROW_MOD32SCAN;
#elif kMatrixHeight == 32
const uint8_t kPanelType = SM_PANELTYPE_HUB75_32ROW_MOD16SCAN;
#elif kMatrixHeight == 16
const uint8_t kPanelType = SM_PANELTYPE_HUB75_16ROW_MOD8SCAN;
#else
#error "Update setting kPanelType"
const uint32_t kMatrixOptions = (SM_HUB75_OPTIONS_NONE);        // see docs for options: https://github.com/pixelmatix/SmartMatrix/wiki
// There are two Adafruit_GFX compatible layers, a Mono layer and an RGB layer, and this example sketch works with either (choose one):
#if 1
#else
  const uint8_t kMonoLayerOptions = (SM_GFX_MONO_OPTIONS_NONE);
  SMARTMATRIX_ALLOCATE_GFX_MONO_LAYER(backgroundLayer, kMatrixWidth, kMatrixHeight, kMatrixWidth, kMatrixHeight, COLOR_DEPTH, kMonoLayerOptions);
  // these backwards compatible ALLOCATE macros also work:
  //SMARTMATRIX_ALLOCATE_SCROLLING_LAYER(backgroundLayer, kMatrixWidth, kMatrixHeight, COLOR_DEPTH, kMonoLayerOptions);
  //SMARTMATRIX_ALLOCATE_INDEXED_LAYER(backgroundLayer, kMatrixWidth, kMatrixHeight, COLOR_DEPTH, kMonoLayerOptions);
// Assign human-readable names to some common 16-bit color values:
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
// enable this to see the intermediate drawing steps, otherwise screen will only be updated at the end of each test (this slows the tests down considerably)
const bool swapAfterEveryDraw = false;
unsigned long testFillScreen() {
  unsigned long start = micros();
  backgroundLayer.fillScreen(BLACK);
  backgroundLayer.fillScreen(RED);
  backgroundLayer.fillScreen(GREEN);
  backgroundLayer.fillScreen(BLUE);
  return micros() - start;
unsigned long testText() {
  backgroundLayer.setCursor(0, 0);
  backgroundLayer.setTextColor(WHITE);  backgroundLayer.setTextSize(1);
  backgroundLayer.println("Hello World!");
  backgroundLayer.setTextColor(YELLOW); backgroundLayer.setTextSize(2);
  backgroundLayer.println(1234.56);
  backgroundLayer.setTextColor(RED);    backgroundLayer.setTextSize(3);
//  backgroundLayer.println(0xDEADBEEF, HEX);
//  backgroundLayer.println();
  backgroundLayer.setTextColor(GREEN);
  backgroundLayer.setTextSize(5);
  backgroundLayer.println("Groop");
  backgroundLayer.println("I implore thee,");
  backgroundLayer.println("my foonting turlingdromes.");
  backgroundLayer.println("And hooptiously drangle me");
  backgroundLayer.println("with crinkly bindlewurdles,");
  backgroundLayer.println("Or I will rend thee");
  backgroundLayer.println("in the gobberwarts");
  backgroundLayer.println("with my blurglecruncheon,");
  backgroundLayer.println("see if I don't!");
unsigned long testLines(uint16_t color) {
  unsigned long start, t;
  int           x1, y1, x2, y2,
                w = backgroundLayer.width(),
                h = backgroundLayer.height();
  x1 = y1 = 0;
  y2    = h - 1;
  start = micros();
  for(x2=0; x2<w; x2+=6) {
    backgroundLayer.drawLine(x1, y1, x2, y2, color);
    if(swapAfterEveryDraw) backgroundLayer.swapBuffers();
  x2    = w - 1;
  for(y2=0; y2<h; y2+=6) {
  t     = micros() - start; // fillScreen doesn't count against timing
  x1    = w - 1;
  y1    = 0;
  y2    = h - 1;
  start = micros();
  x2    = 0;
  t    += micros() - start;
  x1    = 0;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = w - 1;
  x1    = w - 1;
  y1    = h - 1;
  y2    = 0;
  start = micros();
  x2    = 0;
  return t;
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
  unsigned long start;
  int           x, y, w = backgroundLayer.width(), h = backgroundLayer.height();
  start = micros();
  for(y=0; y<h; y+=5) {
    backgroundLayer.drawFastHLine(0, y, w, color1);
  for(x=0; x<w; x+=5) {
    backgroundLayer.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
  int           n, i, i2,
                cx = backgroundLayer.width()  / 2,
                cy = backgroundLayer.height() / 2;
  n     = min(backgroundLayer.width(), backgroundLayer.height());
  start = micros();
  for(i=2; i<n; i+=6) {
    i2 = i / 2;
    backgroundLayer.drawRect(cx-i2, cy-i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
  unsigned long start, t = 0;
  int           n, i, i2,
                cx = backgroundLayer.width()  / 2 - 1,
                cy = backgroundLayer.height() / 2 - 1;
  for(i=n; i>0; i-=6) {
    i2    = i / 2;
    start = micros();
    backgroundLayer.fillRect(cx-i2, cy-i2, i, i, color1);
    // Outlines are not included in timing results
    backgroundLayer.drawRect(cx-i2, cy-i2, i, i, color2);
  return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
  int x, y, w = backgroundLayer.width(), h = backgroundLayer.height(), r2 = radius * 2;
  start = micros();
  for(x=radius; x<w; x+=r2) {
    for(y=radius; y<h; y+=r2) {
      backgroundLayer.fillCircle(x, y, radius, color);
unsigned long testCircles(uint8_t radius, uint16_t color) {
  int           x, y, r2 = radius * 2,
                w = backgroundLayer.width()  + radius,
                h = backgroundLayer.height() + radius;
  // Screen is not cleared for this one -- this is
  // intentional and does not affect the reported time.
  start = micros();
  for(x=0; x<w; x+=r2) {
    for(y=0; y<h; y+=r2) {
      backgroundLayer.drawCircle(x, y, radius, color);
unsigned long testTriangles() {
  int           n, i, cx = backgroundLayer.width()  / 2 - 1,
  n     = min(cx, cy);
  start = micros();
  for(i=0; i<n; i+=5) {
    backgroundLayer.drawTriangle(
      cx    , cy - i, // peak
      cx - i, cy + i, // bottom left
      cx + i, cy + i, // bottom right
      backgroundLayer.color565(0, 0, i));
unsigned long testFilledTriangles() {
  int           i, cx = backgroundLayer.width()  / 2 - 1,
  start = micros();
  for(i=min(cx,cy); i>10; i-=5) {
    start = micros();
    backgroundLayer.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
      backgroundLayer.color565(0, i, i));
    backgroundLayer.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
      backgroundLayer.color565(i, i, 0));
  return t;
unsigned long testRoundRects() {
  int           w, i, i2,
  w     = min(backgroundLayer.width(), backgroundLayer.height());
  start = micros();
  for(i=0; i<w; i+=6) {
    i2 = i / 2;
    backgroundLayer.drawRoundRect(cx-i2, cy-i2, i, i, i/8, backgroundLayer.color565(i, 0, 0));
unsigned long testFilledRoundRects() {
  int           i, i2,
  start = micros();
  for(i=min(backgroundLayer.width(), backgroundLayer.height()); i>20; i-=6) {
    i2 = i / 2;
    backgroundLayer.fillRoundRect(cx-i2, cy-i2, i, i, i/8, backgroundLayer.color565(0, i, 0));
  Serial.begin(115200);
  // wait for Serial to be ready
  delay(1000);
  matrix.setBrightness(128);
  Serial.println(F("Benchmark                Time (microseconds)"));
  Serial.print(F("Screen fill              "));
  Serial.println(testFillScreen());
  delay(500);
  Serial.print(F("Text                     "));
  Serial.println(testText());
  delay(3000);
  Serial.print(F("Lines                    "));
  Serial.println(testLines(CYAN));
  delay(500);
  Serial.print(F("Horiz/Vert Lines         "));
  Serial.println(testFastLines(RED, BLUE));
  delay(500);
  Serial.print(F("Rectangles (outline)     "));
  Serial.println(testRects(GREEN));
  delay(500);
  Serial.print(F("Rectangles (filled)      "));
  Serial.println(testFilledRects(YELLOW, MAGENTA));
  delay(500);
  Serial.print(F("Circles (filled)         "));
  Serial.println(testFilledCircles(10, MAGENTA));
  delay(500);
  Serial.print(F("Circles (outline)        "));
  Serial.println(testCircles(10, WHITE));
  delay(500);
  Serial.print(F("Triangles (outline)      "));
  Serial.println(testTriangles());
  delay(500);
  Serial.print(F("Triangles (filled)       "));
  Serial.println(testFilledTriangles());
  delay(500);
  Serial.print(F("Rounded rects (outline)  "));
  Serial.println(testRoundRects());
  delay(500);
  Serial.print(F("Rounded rects (filled)   "));
  Serial.println(testFilledRoundRects());
  delay(500);
  Serial.println(F("Done!"));
  for(uint8_t rotation=0; rotation<4; rotation++) {
    backgroundLayer.setRotation(rotation);
    testText();
    delay(1000);
FWIW, pjrc.com just released the Teensydunion 1.58 official version that has the GCC 11 compiler in it, and hence the warnings in the SmartMatrix library.
