// Copyright 2017 Espressif Systems (Shanghai) PTE LTD
// Licensed under the Apache License, Version 2.0 (the “License”);
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
// Apache License, Version 2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an “AS IS” BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
#if defined(ESP32)
#include <stdio.h>
#include <stdint.h>
#include <stddef.h>
#include <string.h>
#include “freertos/FreeRTOS.h”
#include “freertos/task.h”
#include “freertos/semphr.h”
#include “freertos/queue.h”
#include “soc/i2s_struct.h”
#include “soc/i2s_reg.h”
#include “driver/periph_ctrl.h”
#include “driver/gpio.h”
#include “hal/gpio_types.h”
#include “esp32/rom/lldesc.h” // instead of “rom/lldesc.h”
#include “esp_heap_caps.h”
#include “esp32_i2s_parallel.h”
typedef struct {
volatile lldesc_t *dmadesc_a, *dmadesc_b;
int desccount_a, desccount_b;
} i2s_parallel_state_t;
static i2s_parallel_state_t *i2s_state[2]={NULL, NULL};
callback shiftCompleteCallback;
void setShiftCompleteCallback(callback f) {
shiftCompleteCallback = f;
volatile bool previousBufferFree = true;
static int i2snum(i2s_dev_t *dev) {
return (dev==&I2S0)?0:1;
// Todo: handle IS20? (this is hard coded for I2S1 only)
static void IRAM_ATTR i2s_isr(void* arg) {
REG_WRITE(I2S_INT_CLR_REG(0), (REG_READ(I2S_INT_RAW_REG(0)) & 0xffffffc0) | 0x3f);
// at this point, the previously active buffer is free, go ahead and write to it
if(shiftCompleteCallback)
shiftCompleteCallback();
#define DMA_MAX (4096-4)
// comment out unused functions, unmodified from Sprite_TM
#if 0
//Calculate the amount of dma descs needed for a buffer desc
static int calc_needed_dma_descs_for(i2s_parallel_buffer_desc_t *desc) {
int ret=0;
for (int i=0; desc[i].memory!=NULL; i++) {
ret+=(desc[i].size+DMA_MAX-1)/DMA_MAX;
return ret;
static void fill_dma_desc(volatile lldesc_t *dmadesc, i2s_parallel_buffer_desc_t bufdesc) {
int n=0;
for (int i=0; bufdesc[i].memory!=NULL; i++) {
int len=bufdesc[i].size;
uint8_t data=(uint8_t)bufdesc[i].memory;
while(len) {
int dmalen=len;
if (dmalen>DMA_MAX) dmalen=DMA_MAX;
dmadesc[n].size=dmalen;
dmadesc[n].length=dmalen;
dmadesc[n].buf=data;
dmadesc[n].eof=0;
dmadesc[n].sosf=0;
dmadesc[n].owner=1;
dmadesc[n].qe.stqe_next=(lldesc_t)&dmadesc[n+1];
dmadesc[n].offset=0;
len-=dmalen;
data+=dmalen;
n++;
// set EOF bit in last dma descriptor
dmadesc[n-1].eof=1;
// link end of list back to beginning so current frame will be refreshed continously
dmadesc[n-1].qe.stqe_next=(lldesc_t*)&dmadesc[0];
printf("fill_dma_desc: filled %d descriptors\n", n);
// size must be less than DMA_MAX - need to handle breaking long transfer into two descriptors before call
void link_dma_desc(volatile lldesc_t *dmadesc, volatile lldesc_t *prevdmadesc, void *memory, size_t size) {
if(size > DMA_MAX) size = DMA_MAX;
dmadesc->size = size;
dmadesc->length = size;
dmadesc->buf = memory;
dmadesc->eof = 0;
dmadesc->sosf = 0;
dmadesc->owner = 1;
dmadesc->qe.stqe_next = 0; // will need to set this elsewhere
dmadesc->offset = 0;
// link previous to current
if(prevdmadesc)
prevdmadesc->qe.stqe_next = (lldesc_t*)dmadesc;
static void gpio_setup_out(int gpio, int sig) {
if (gpio==-1) return;
PIN_FUNC_SELECT(GPIO_PIN_MUX_REG[gpio], PIN_FUNC_GPIO);
gpio_set_direction(gpio, GPIO_MODE_DEF_OUTPUT);
gpio_matrix_out(gpio, sig, false, false);
static void gpio_setup_out_invert(int gpio, int sig) {
gpio_matrix_out(gpio, sig, true, false);
static void dma_reset(i2s_dev_t *dev) {
dev->lc_conf.in_rst=1; dev->lc_conf.in_rst=0;
dev->lc_conf.out_rst=1; dev->lc_conf.out_rst=0;
static void fifo_reset(i2s_dev_t *dev) {
dev->conf.rx_fifo_reset=1; dev->conf.rx_fifo_reset=0;
dev->conf.tx_fifo_reset=1; dev->conf.tx_fifo_reset=0;
// commenting out to avoid working on the wrong similar-looking code
#if 0
void i2s_parallel_setup(i2s_dev_t *dev, const i2s_parallel_config_t *cfg) {
//Figure out which signal numbers to use for routing
printf(“Setting up parallel I2S bus at I2S%d\n”, i2snum(dev));
int sig_data_base, sig_clk;
if (dev==&I2S0) {
sig_data_base=I2S0O_DATA_OUT0_IDX;
sig_clk=I2S0O_WS_OUT_IDX;
} else {
if (cfg->bits==I2S_PARALLEL_BITS_32) {
sig_data_base=I2S1O_DATA_OUT0_IDX;
} else if (cfg->bits==I2S_PARALLEL_BITS_16) {
//Because of… reasons… the 16-bit values for i2s1 appear on d8…d23
sig_data_base=I2S1O_DATA_OUT8_IDX;
} else { // I2S_PARALLEL_BITS_8
sig_clk=I2S1O_WS_OUT_IDX;
//Route the signals
for (int x=0; x<cfg->bits; x++) {
gpio_setup_out(cfg->gpio_bus[x], sig_data_base+x);
//ToDo: Clk/WS may need inversion?
gpio_setup_out(cfg->gpio_clk, sig_clk);
//Power on dev
if (dev==&I2S0) {
periph_module_enable(PERIPH_I2S0_MODULE);
} else {
periph_module_enable(PERIPH_I2S1_MODULE);
//Initialize I2S dev
dev->conf.rx_reset=1; dev->conf.rx_reset=0;
dev->conf.tx_reset=1; dev->conf.tx_reset=0;
dma_reset(dev);
fifo_reset(dev);
//Enable LCD mode
dev->conf2.val=0;
dev->conf2.lcd_en=1;
// Enable "One datum will be written twice in LCD mode" - for some reason, if we don't do this in 8-bit mode, data is updated on half-clocks not clocks
if(cfg->bits == I2S_PARALLEL_BITS_8)
dev->conf2.lcd_tx_wrx2_en=1;
dev->sample_rate_conf.val=0;
dev->sample_rate_conf.rx_bits_mod=cfg->bits;
dev->sample_rate_conf.tx_bits_mod=cfg->bits;
dev->sample_rate_conf.rx_bck_div_num=4; //ToDo: Unsure about what this does...
// because conf2.lcd_tx_wrx2_en is set for 8-bit mode, the clock speed is doubled, drop it in half here
dev->sample_rate_conf.tx_bck_div_num=2;
else
dev->sample_rate_conf.tx_bck_div_num=1; // datasheet says this must be 2 or greater (but 1 seems to work)
dev->clkm_conf.val=0;
dev->clkm_conf.clk_sel = 2;
dev->clkm_conf.clk_en=1;
dev->clkm_conf.clkm_div_a=63;
dev->clkm_conf.clkm_div_b=63;
//We ignore the possibility for fractional division here, clkspeed_hz must round up for a fractional clock speed, must result in >= 2
dev->clkm_conf.clkm_div_num=80000000L/(cfg->clkspeed_hz + 1);
dev->fifo_conf.val=0;
dev->fifo_conf.rx_fifo_mod_force_en=1;
dev->fifo_conf.tx_fifo_mod_force_en=1;
//dev->fifo_conf.tx_fifo_mod=1;
dev->fifo_conf.rx_data_num=32; //Thresholds.
dev->fifo_conf.tx_data_num=32;
dev->fifo_conf.dscr_en=1;
dev->conf1.val=0;
dev->conf1.tx_stop_en=0;
dev->conf1.tx_pcm_bypass=1;
dev->conf_chan.val=0;
dev->conf_chan.tx_chan_mod=1;
dev->conf_chan.rx_chan_mod=1;
//Invert ws to be active-low... ToDo: make this configurable
//dev->conf.tx_right_first=1;
dev->conf.tx_right_first=0;
//dev->conf.rx_right_first=1;
dev->conf.rx_right_first=0;
dev->timing.val=0;
//Allocate DMA descriptors
i2s_state[i2snum(dev)]=malloc(sizeof(i2s_parallel_state_t));
i2s_parallel_state_t *st=i2s_state[i2snum(dev)];
st->desccount_a=calc_needed_dma_descs_for(cfg->bufa);
st->desccount_b=calc_needed_dma_descs_for(cfg->bufb);
st->dmadesc_a=heap_caps_malloc(st->desccount_a*sizeof(lldesc_t), MALLOC_CAP_DMA);
st->dmadesc_b=heap_caps_malloc(st->desccount_b*sizeof(lldesc_t), MALLOC_CAP_DMA);
//and fill them
fill_dma_desc(st->dmadesc_a, cfg->bufa);
fill_dma_desc(st->dmadesc_b, cfg->bufb);
//Reset FIFO/DMA -> needed? Doesn't dma_reset/fifo_reset do this?
dev->lc_conf.in_rst=1; dev->lc_conf.out_rst=1; dev->lc_conf.ahbm_rst=1; dev->lc_conf.ahbm_fifo_rst=1;
dev->lc_conf.in_rst=0; dev->lc_conf.out_rst=0; dev->lc_conf.ahbm_rst=0; dev->lc_conf.ahbm_fifo_rst=0;
dev->conf.tx_reset=1; dev->conf.tx_fifo_reset=1; dev->conf.rx_fifo_reset=1;
dev->conf.tx_reset=0; dev->conf.tx_fifo_reset=0; dev->conf.rx_fifo_reset=0;
// setup I2S Interrupt
SET_PERI_REG_BITS(I2S_INT_ENA_REG(0), I2S_OUT_EOF_INT_ENA_V, 1, I2S_OUT_EOF_INT_ENA_S);
// allocate a level 1 intterupt: lowest priority, as ISR isn't urgent and may take a long time to complete
esp_intr_alloc(ETS_I2S0_INTR_SOURCE, (int)(ESP_INTR_FLAG_IRAM | ESP_INTR_FLAG_LEVEL1), i2s_isr, NULL, NULL);
//Start dma on front buffer
dev->lc_conf.val=I2S_OUT_DATA_BURST_EN | I2S_OUTDSCR_BURST_EN | I2S_OUT_DATA_BURST_EN;
dev->out_link.addr=((uint32_t)(&st->dmadesc_a[0]));
dev->out_link.start=1;
dev->conf.tx_start=1;
void i2s_parallel_setup_without_malloc(i2s_dev_t *dev, const i2s_parallel_config_t *cfg) {
if (dev==&I2S0) {
sig_data_base=I2S0O_DATA_OUT8_IDX;
} else {
//Route the signals
if(cfg->clk_inversion)
gpio_setup_out_invert(cfg->gpio_clk, sig_clk);
else
//Power on dev
if (dev==&I2S0) {
} else {
dma_reset(dev);
fifo_reset(dev);
//Enable LCD mode
dev->conf2.val=0;
else
dev->conf1.val=0;
dev->timing.val=0;
assert(i2s_state[i2snum(dev)] != NULL);
st->desccount_a = cfg->desccount_a;
st->desccount_b = cfg->desccount_b;
st->dmadesc_a = cfg->lldesc_a;
st->dmadesc_b = cfg->lldesc_b;
//Flip to a buffer: 0 for bufa, 1 for bufb
void i2s_parallel_flip_to_buffer(i2s_dev_t dev, int bufid) {
int no=i2snum(dev);
if (i2s_state[no]==NULL) return;
lldesc_t active_dma_chain;
if (bufid==0) {
active_dma_chain=(lldesc_t)&i2s_state[no]->dmadesc_a[0];
} else {
active_dma_chain=(lldesc_t)&i2s_state[no]->dmadesc_b[0];
// setup linked list to refresh from new buffer (continuously) when the end of the current list has been reached
i2s_state[no]->dmadesc_a[i2s_state[no]->desccount_a-1].qe.stqe_next=active_dma_chain;
i2s_state[no]->dmadesc_b[i2s_state[no]->desccount_b-1].qe.stqe_next=active_dma_chain;
// we're still refreshing the previously buffer, so it shouldn't be written to yet
previousBufferFree = false;
bool i2s_parallel_is_previous_buffer_free() {
return previousBufferFree;
