Teensy 3.5 with vers 3 sm board and Aurora.?
ok… after playing around with it for a while… i have noticed one other issue…, when running with the standard menu screen… pattern, settings etcs scrolling everything is fine… or if i have it with just the pattern playing… when i place the clock on, which is one of the reason i use it… all the pattens slow or freeze… playback drops to about 50% on some, but spiro stops on the frame its on and repeats it over and over… if i remove the clock it resumes normal playback…
