PACKAGES:
- framework-arduinoespressif32 @ 3.20011.230801 (2.0.11)
- tool-esptoolpy @ 1.40501.0 (4.5.1)
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Converting MultiRowRefreshMapping.ino
LDF: Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 40 compatible libraries
Scanning dependencies…
Dependency Graph
|-- SmartMatrix @ 4.0.3
Building in release mode
Compiling .pio\build\nodemcu-32s\src\MultiRowRefreshMapping.ino.cpp.o
the err msg is :/arduino_lib/SmartMatrix/src/esp32_i2s_parallel.c:129:21: error: 'GPIO_PIN_MUX_REG' undeclared (first use in this function) PIN_FUNC_SELECT(GPIO_PIN_MUX_REG[gpio], PIN_FUNC_GPIO);
arduino_lib/SmartMatrix/src/esp32_i2s_parallel.c:384:69: error: 'ESP_INTR_FLAG_LEVEL1' undeclared (first use in this function); did you mean 'ESP_ERR_FLASH_BASE'?
esp_intr_alloc(ETS_I2S1_INTR_SOURCE, (int)(ESP_INTR_FLAG_IRAM | ESP_INTR_FLAG_LEVEL1), i2s_isr, NULL, NULL);
ESP_ERR_FLASH_BASE
