I’m currently getting 241 fps and no matter how simple the animation is - I’m stuck with that. I would the fps expect to change depending on animation complexity, but they don’t.
Currently I’m using the FastLED example. 32x32, 24 bit.
This are the settings:
//#include <MatrixHardware_Teensy3_ShieldV1toV3.h> // SmartMatrix Shield for Teensy 3 V1-V3
//#include <MatrixHardware_ESP32_V0.h> // This file contains multiple ESP32 hardware configurations, edit the file to define GPIOPINOUT (or add #define GPIOPINOUT with a hardcoded number before this #include)
//#include "MatrixHardware_Custom.h" // Copy an existing MatrixHardware file to your Sketch directory, rename, customize, and you can include it like this
#include <FastLED.h>
const uint16_t kMatrixWidth = 32; // Set to the width of your display, must be a multiple of 8
const uint16_t kMatrixHeight = 32; // Set to the height of your display
const uint8_t kPanelType = SM_PANELTYPE_HUB75_32ROW_MOD16SCAN; // Choose the configuration that matches your panels. See more details in MatrixCommonHub75.h and the docs: https://github.com/pixelmatix/SmartMatrix/wiki
//SMARTMATRIX_ALLOCATE_SCROLLING_LAYER(scrollingLayer, kMatrixWidth, kMatrixHeight, COLOR_DEPTH, kScrollingLayerOptions);
