“The chips on this board are FM6126A. To drive them from a ESP8266 based Wemos D1 Mini Pro, I had to use the updated PxMatrix library from github (update as-of Jan 29, 2019), and change the code in the setup in my sketch, and a call to display.setDriverChip(FM6126A)”
I had a look in the lib, and found this code that’s different:
Amongst other things, the chip needs to be configured before taking to it, and then the protocol seems slightly different.
Given that the work has been done in PxMatrix, would it be easy enough to add in SmartMatrix?
I’m working on integrating FM6126A Reset into SmartMatrix Library. I’m operating under the assumption that this reset sequence can be sent at the beginning before matrix.begin() is called (or during matrix.begin()), and doesn’t need to be sent any any point later in the sketch. Do you agree?
I only see two exceptions to this:
If there is a power issue that allows the SmartMatrix sketch to keep running, but puts the FM6126A chips back to their default config
If someone hot-swaps panels while the sketch is running, or applies power to their panel after powering up their micro controller running SmartMatrix
If I implement the FM6126A reset only at the beginning, the only solution to these exceptions happening is to reset the microcontroller, starting the sketch over at the beginning where the reset sequence is sent. Is that acceptable?
As discussed on the bug, it would be good for the vast majority of cases.
I can see times where it would be helpful to send a reset at runtime though. You said it would be tricky if there is a latch, but for those of us that are using simple direct wiring, no such issue, so maybe supporting it for at least direct wiring would be easy enough?
Yep, should be possible. Easy? Not so sure. Would need to pause DMA, switch the lines over to GPIO, toggle the lines, switch back, enable DMA again, hopefully not noticeably flicker. I’ll implement the easy way first, and keep the runtime option for later.
There’s some updates here, describing FM6126A support that’s stable for Teensy, and experimental with ESP32. I’d appreciate feedback on the ESP32 support if you’re trying it yourself as I only have one panel here.
@Louis I took apart another project with FM2616 and it’s currently wired into an ESP32 for testing. Do you think you’d have code to test in a day or two at most, or should I put everything back together?
(to be clear, I don’t need this myself anymore, my FM2616 panels are plugged into rPis)
